Next to its younger bigger brother:
Dan McBoost's CQ -> S2/RS2 Project - NY USA
I like the bonnet too. and i would like one of those US nr plate recess things.
Me too,
Originally posted by Christophski View PostAm Loving the Carbon Bonnet. How much are they and where do you get them from??? My Avant needs one!
Thanks.
I lowered the front wipers to where they should be and then took a look at the rear wiper...
Hmm, it's ugly and after owning so many hatchbacks, its probably useless so I took it off.
I then removed the under cover to remove the motor.
Then I had a hole.
I measured the hole and my friend at work made this:
The part with its seal sunk into place:
The part and the seal separate:
The parts needed for install:
The bottom installed:
The top installed:
I still have to remove it and wet sand and buff around it, but for now its perfect. Does not leak at all, even in a laser wash.
Cheers,
Dan
He had his reasons and my garage was where he wanted it for reasons like this:
My previous set up is for sale. Photos are located: http://mcboost.com/depot
Someone on some forum asked for a far shot of the wiper delete:
I think I have a headlight problem (and this is not counting the 10 in my attic)
One thing to check with your lights if you're planning on putting hids on it is that when you put the main beam on you're ellipsoid eye ball part does not turn off.
looking smart tho, one thing you might want to try is either sourcing a rs2 grille or blacking the chrome around the grille.
Originally posted by Dan McBoost View Post
Have you fitted LED's to the inside corners of the fogs? on the first picture it seems, that the light is coming from the center and not from the fog lens. If so, could you give a little close pictures of it?
Cheers,
Zoig
