well i've been lurking round these parts for a while now so i thought i'd better start a thread on my project. First off i live in new zealand where audi's are rare as rocking horse crap so most of the parts i've had to import. I bought a very clean and straight 1987 kv quattro coupe locally (well over 1000kms away) and quickly stripped it out. I bought an aan in from the states along with all the rebuild parts thanks to 034 motorsport. I'm aiming for 400-450 hp so i went with a new garret 3071 which i sourced locally. I then moved onto the brakes which i went for a set of mitsibushi evo 5-10 330x32 rotors and nissan skyline 4 pot calipers. The car came with a set of koni internally adjustable shocks which i had rebuilt but will probably end up replacing with koni double externally adjustable shocks and I built a set of adjustable spring platforms with king springs. The cage went in but i am going to modify it to pick up the rear subframe mounts shortly (as soon as i can convince my boss to take the car to work)
In the meantime i had sourced a set of A2 quattro guards and rear bumper locally and had to bring in the bonnet, grill, front bumper, and rear wing in from sweden (with help from zlobo off this forum - big thanks mate!) Lots of other things have been done, like an ali fuel tank, boot mounted radiator, balance bar brakes etc but this is already turning into a novel so i'll spare you for now.
The next "great idea" i had was to bin the 016 drivetrain and replace it this a 5 speed subaru drivetrain. The advantages are i have a mechanical front and rear LSD and a variable viscous centre LSD (DCCD) and i plan to install a dog box gearset once its up and running and i'm happy with the ratio's . so far i have the box and motor mated together and mounted on the original engine mounts but this is an ongoing saga........
heres some pics
heres some pics
