Ok, Got my 1995 S2 just less than two weeks ago. Knowing full well from my lurking here that I will be digging deep in more ways than one. This is a great forum
, I may not say much, but most of my questions are answered by the search function
I decided to collect it by transporter, as the guy selling it said it was idle for a while, and I heard some brake scraping on its test drive.
Interior is perfect, but radio is the sony unit, aparently standard on uk cars, so I will replace that with a gamma and phatbox. Radio wiring is untouched.
First order of business was check out the front axle see what the scraping was all about.
While I did notice that the brake fluid res. was full, with a top up bottle in boot, (that should set alarm bells going and was a bargining point)
I couldn't have imagined it was this bad, maybe from uk salty roads and utter lack of maintainance in the last 2 years just added up to a load of rust. ARB tie rods are also shot. I changed these on an 80 years ago, went from steel to plastic. I was suspicous at the time. Didn't expect to see plastic ones on the S2.
Porsche caliper upgrade is on the way, but I really want to compare stock to upgraded so I ordered a set of standard pads.
Is that a piston in your pocket, or are you just happy to see me
Seeing this ammount of neglect, I had to give the engine a once over, a quick check on the VAGCOM reported no errors and it purrs like a kitten. I want to keep it
that way so I have to change the cam belt, even though I have a docked saying belt was done at 138K and there is now 149k on it now, the belt really needs to be redone.
Especially the bottom belt pully. Front bumper was loose, bolts were not even tightened up, and meet more and more of them that were loose as I made my way into the bay.
Aux rad was changed 30k miles ago, and although looks bad it may be just be exterior surface corrosion from being idle. Not too worried about the aux rad anyway.
IC looks straight but while there is surface corrosion on the outside, I am more worried about loose bits of oxide from the inside working its way into the engine.
Air baffle/guide to the oil cooler looks quite bad , repair may sort it out. Also got a oil leak coming from a sender. My todo list is getting quite large.
Heat guard is rusted quite a bit, seems to be the order of the day. Then I spotted this. (oil feed or return to turbo)
I would really like to replace those bolts, They could snap on removal, maybe I could extract the stud with a dremel
I kid, I kid.
And an oil leak from a sender
And really really rusty allens on the main pully
Anyway this is day 1 and 2 of the strip down, cam belt and gear is on order from the stealers, he got quite excited when I mentioned I was looking
for parts for an S2, I could hear whispering in the background, 'whats an S2?' . He also complimented me on my accurate list of cambelt parts thanks to Pauls pdf.
Funny irish facts.
A8 314mm discs are €122.50+21.5%vat each not for the pair. I laughed in his face at that one.
Original front pads are €169+vat, €69+vat for rears. Again I was in stitches.
RS2 caliper adapters €160+vat for pair.
I kid, I kid.
Funny irish facts.
