My Audi S2 600Hp+ project 56k warning
This topic is closed.
  • chipsenter
    replied
    This is how it will sound with the CT67 Turbo
    My friends Winter track Audi .
    Volume UP !
  • terrybullwon
    replied
    Aero catches fitted
    Also found out that my gear linkage was rubbing on a 90deg -3 hose on the slave cylinder. So i changed it to a Banjo £30 lighter
  • Bram
    replied
    Looking good chef, even high up it's feet. Probably going to see it high up front anyway when you launch it at the drag track
  • terrybullwon
    replied
    Keeping the dream alive.......
    So far i have sprayed the inside white, with no rubber flooring left (about 15kg)
    welded in a anti lag micro switch under the clutch peddle. started to make a turbo brace.
    Welded the bucket seats in.
  • Puglife
    replied
    Originally posted by terrybullwon
    Ooh yeah..... It sounds ****ing awsome!!!!!!!!!
    Vids or STFU Seriously james I'm excited to see the car all done Blood sweat and tears borther
  • Rocco
    replied
    James¡¡
    it is reliable and good install two EGT sensors in the turbo hotside??
    one for example for the Aftermarket that you have and the other one for use it in a gauge...
    and...it is better fit in in the exhaust manifold?? or the reads will not be ood??
  • smiler
    replied
  • terrybullwon
    replied
  • terrybullwon
    replied
    Just got back from running the car up. Getting ready for a drive Sunday! Lamba is still high I will sort this out tonight after more work
  • repo
    replied
    No antilag
  • Jonnybravo
    replied
    Anti Lag ?
  • terrybullwon
    replied
    Originally posted by Jonnybravo
    1 bar @ idle ?
    Yes neutral gear
  • Jonnybravo
    replied
    1 bar @ idle ?
  • terrybullwon
    replied
    Good luck to you Alex!
    Repo I hope I can make that pretty easy!
  • repo
    replied
    Repo just mapped another engine very much the same as mine and at half throttle it had 1bar on idle.
    Not exactly idle, but neutral. Which I bet You ment...
    e: Here's a goal for You, this was less than 2bar and suffered from lack of spark power. You can see the power going up and down because of misfiring...
