3b s2 coupe resurrection
    replied
    Built like the Forth Bridge [emoji6]
    replied
    Great cheers mate. Yeah there's a bit on there. Just shows what you need to do to stiffen up a car with such a huge hatch... Sounds familiar
  • andy10v
    replied
    I know, just need to decide NA or boost, NA tuning is expensive for a small power increase, cams, tubular manifolds, decats and a remap could be fun though. Should probably learn to drive properly it before just chasing power
    Yup big rear brace, plus lots of boxing and triangulation
    Sorry about the bad pictures, camera did not want to play ball
    Front
    Tunnel
    Rear W
    Rear
    Actually, this is probably a lot clearer.
    replied
    ...And so it begins
    Pics of the braces pls Andy
    I know the rear tower brace is completely massive!
  • andy10v
    replied
    Well not modifying the 350z.......
    Oil cooler mock up
    Spare diff for a quaife
    Seat subframe
    This car has so many chassis braces its crazy! The subframe is already massive!
  • andy10v
    replied
    One loft emptied, one fills up.
    Gearbox and the bonnet are aside for you, I will pop other potentially useful stuff aside as well.
  • sjw185
    replied
    Originally posted by andy10v
    Cheers Steve, thanks for rescuing!
    Good to see you guys again, good luck with the build(s).
    How was the drive home?
    Hope your mate enjoys his new toy as well.
    Now just need to finish clearing out the garage, anybody want a 3B engine?
    Drive was good no problems with the trailer, it was like smokie and the bandit with my mate in the E36
    Got home about 1230 it never stopped raining!
    Emptied out the S2 today and started to clear the loft
    Remember to keep unwanted bits cause I will be back for a look next time I am down.
    cheers
    Steve
  • andy10v
    replied
    replied
    Originally posted by Error404
    Cool, glad it's found a new home
    +1 ^^
    replied
  • sjw185
    replied
    S2 moving house
    Thanks for all your help Andy.
    Hopefully you will see it at Knockhill again
    cheers
    Steve
  • andy10v
    replied
    Originally posted by mackenzie50
    you can never have too many wheels !
    I think my girlfriend might disagree, she was muttering something about plant pots the other day
    4X17" BBS
    4x17" Avus
    4x18" rays
    4X16" snows
    Various spare 16" avus
    Plus the wheels fitted to the cars.....
    I have no idea what her point is
  • mackenzie50
    replied
    [QUOTE=andy10v;867659]
    Michelin Pilot Super Sports
    replied
  • andy10v
    replied
    Survived the first track day!
    Is feels like the 350 has loads more grip on corner entry and mid corner than the S2, you can just turn in and lean on the front so much, where the S2 would just start too push wide. I could make the S2 rotate hard by trail braking or lifting, but both are rather aggressive, this just turns in beautifully.
    However.... on corner exit there is a severe lack or traction when the throttle is applied, I have been spoilt by quattro and it shows!
    If I cause the car to slide I can balance it on the throttle, more throttle, more slide, less throtttle and the car comes back into line, however when the back end stepped out on the exit at Clark I instinctively applied throttle and steered into the slide which would straighten the S2 out, but instead resulted in a rather fast spin into the gravel
    So more practice required
    Aside from that it has just been maintence
    Old Pads
    New Pads
    S2 still lurking
    OEM airbox from ebay
    To replace the hot air sucker
