RS2 Tuned by SKN Slovenija
  • VU-002-RS
    • Oct 2009
    • 128
    • Country: Croatia
    #61
    silikon was not in plan, wen i weldet all tugeder it was 2 stiff (hard, non muvment)!! i have standard engine mounts &
    a got skeard 2 put onli one pegasus clamp on dat said!!!
    my english is not so good, i hope you all will forgive me !!!
    • gedu
      • Feb 2007
      • 295
      #62
      You have stock motormounts, and think that 1cm clearance between radiator and intake manifold is enough? My AAN moved that 1cm when revving in place in neutral...
      All quattro products have been dermatologically tested, and are safe for daily use.
      • VU-002-RS
        • Oct 2009
        • 128
        • Country: Croatia
        #63
        • terrybullwon
          • Mar 2006
          • 8782
          Is that a thermo couple boss, to messure inlet temps?
          Chef
          • VU-002-RS
            • Oct 2009
            • 128
            • Country: Croatia
            #65
            it is aqwamist!!!
            • terrybullwon
              • Mar 2006
              • 8782
              Ah water injection. ECU controled?
              Chef
              • VU-002-RS
                • Oct 2009
                • 128
                • Country: Croatia
                #67
                1S sistem!!
                • VU-002-RS
                  • Oct 2009
                  • 128
                  • Country: Croatia
                  #68
                  new place 4 servo pump & alternator
                  • VU-002-RS
                    • Oct 2009
                    • 128
                    • Country: Croatia
                    #69
                    job is don
                    RS saunds great!!
                    i still have vacum problem, i mast dill wit it (no problem)
                    • +500hp
                      • Dec 2004
                      • 51
                      #70
                      I must say; big job, a lot of work...
                      Looks great.
                      I hope to test it asap
                      • VU-002-RS
                        • Oct 2009
                        • 128
                        • Country: Croatia
                        #71
                        vacum problem gets solved !!
                        vacum is solved !!!!
                        • CoCaine
                          • May 2008
                          • 216
                          • Home: Romania Current: Spain
                          #72
                          Great job.
                          • repo
                            • Dec 2004
                            • 893
                            Gotta love Your spelling, dude, You spell a bit like the Chef, only a bit better .
                            Nice You got everything sorted. Let us know what kind of effect it made to performance and/or throttle response.
                            • VU-002-RS
                              • Oct 2009
                              • 128
                              • Country: Croatia
                              #74
                              The reason why I was not riding my RS and try a new intake, because I had no rear brake
                              Yesterday I drove it and I did not felt changes in performance at low rpm A / F is rich(my engine map is same es byfore) and at higher RPM the car is behaving the same as before!!throttle response is different is not much better
                              but we'll see after remap!!! I must reduce the fuel in the vacuum!!
                              • Bram
                                • Aug 2006
                                • 2582
                                Looking good that car. Who will map and when will your car get mapped?
