Hi all!
I think it's time to introduce you all to my car, a 1991 S2 that I imported here to Iceland from Sweden in the winter 2007-2008 with help from my brother and Daniel at Arctic Tuning. In february 2008 I received a big package from Sweden with some nice bits, I bought the Arctic Tuning 450hp kit +pistons and rods!
The spec list:
Engine: 3B 2226cc 20v turbo
Turbo from GIK, Sweden
Exhaust manifold from CP-S in Sweden
Cams from Arctic-Tuning
Home made intake manifold
Delphi 525cc injectors
Bosch 044 fuel pump
2x Bosch BOV
Bigger MAF housing
3bar MAP sensor
Bigger FMIC
Vems round gauge, lambda and EGT
Auto Meter boost gauge
Sachs Racing clutch
Steel head gasket
3" exhaust, home made with mandarel bends
3" down pipe
Red Line air filter
Steel cam belt pulley on crank
Stiffer WG spring
78°C thermostat
Modified throttle body
H-beam rods
Forged pistons
Remapped chips for this setup
Stiffer engine mounts
The day after I got the car
How it looked like, 2.2l 5cyl 20v turbo
Delivery from Sweden
Camshafts from Arctic Tuning
Eagle rod
525cc injectors
Turbo from GIK and CP-S exhaust manifold
Bosch 044 fuel pump
Lets get started
Original K24 KKK
Engine out
The spec list:
Bosch 044 fuel pump
2x Bosch BOV
Bigger MAF housing
3bar MAP sensor
Bigger FMIC
Sachs Racing clutch
Steel head gasket
3" down pipe
Red Line air filter
Stiffer WG spring
78°C thermostat
H-beam rods
Forged pistons
Eagle rod
525cc injectors
Bosch 044 fuel pump
Lets get started
Original K24 KKK
Engine out
