Hello friends, with this 3D I want show you the pictures of the complete restoration of my S2 Coupe ABY.
Here you can see the pictures from the day when I bought it to now that is under complete restoration.
First pictures when I bought it in September 2006
October 2006
It's time to change cam belt and all aux belts, change also water pump, cam belt bearing, all 5 spark plugs and spark plugs connectors, valve cover gasket, oil and oil filter, gearbox and rear diff oil, brake oil, mount K&N air filter with RS2 airbox, power steering oil, coolant, brake bomb, rear brake pads and aircon filter.
From October 2006 to December 2007 I have not used the car and I have park it in my garage
From December 2007 to December 2009 I have used the car as a daily driver, here you can see a picture
From December 2009 to now I have not used the car and now I decided to completely refurb it
Here you can see a lot of pictures of the completely refurb project
I decided to change central console for a better one, I have mount original gearbox knob new from Audi and original S2 steering wheel.
I have also change all burnt bulbs in the central console switch and in mirrors switch and one led in a window switch
Some pictures of the interior during work
I have repaint ashtray cover because was a bit spoiled
Final result
Completely refurb project proceed
I have completely clean central tunnel
More pictures and details tomorrow, this is the beginning.
I want mount H&R spring and Koni adjustable shock absorbers or completely H&R coilover kit, front RS2 ARB, replace all bushes with new ones, replace front and rear brake disk and pads and brake pipes, replace clutch, pressure plate, pressure plate bearing, refurb completely or change with a better one gearbox, change or refurb servo pump and steering box, refurb completely engine and turbo, mount RS2 exhaust manifold and intercooler with cross member, mount complete Samco hoses kit and then completely repaint it.
Alessio
October 2006
Final result
Alessio
and now I must solve also this problem. I think that water come from fuse box or near fuse box.
