OK so some of you may know from the Knockhill thread that my timing belt slipped when the belts in front of it went.
I checked yesterday and it slipped one tooth (or one turn less one tooth!) so I re timed it and cranked it over on the off chance I was lucky! No such luck... 8 out the 10 inlet valves are bent. No biggy really I guess, like I said at the time, I'd rather that that smash it into the tyre wall!
So the question is, what do I do? Bear in mind labour costs nothing when suggesting!
I need to replace a thrust bearing as it doing my t1ts in! So should I get an uprated clutch? (I am intending putting in a 3071/6 or CT355 soonish) If so, what one for an ABY?
Should I take the block out and do the rods? I am thinking yes as its half out anyway...
Should I put in the 7a cams, or try get hold of ADU ones, or are ABY ones fine for the turbos I am looking at?
Where is the best place to get the parts I need? i.e. ARP head bolts, gasket, rods...?
If only I had bought a k26 Evo EM rather than the T3 one, I could have fitted it too! Now I need to think if I should sell the EVO IC that has never been fitted, and get a reverse one from Wagner too...
Ahh, so many decisions!
Thanks for any advice guys
Mike
Mike
