Timing Belt slippage - What to do?!
  • Flat on my back
    • Jan 2007
    • 2449
    Post 113 for my list...
    Carlos.
    • madpugger
      • Sep 2007
      • 1901
      Originally posted by S2central.net
      Paper head gasket was phased out with 3B... steel item is much heavier duty.
      I thought this too, mine is one of the last cars made, and it deffo has not got an all steel gasket, and it is the original one from factory....
      So, do ARP not do head bolts? I don't want studs!
      Le Mans 2012
      Nurburgring 700
      1995 S2 Avant
      • madpugger
        • Sep 2007
        • 1901
        Originally posted by Flat on my back
        Cheers Carl, good thread
        Le Mans 2012
        Nurburgring 700
        1995 S2 Avant
        • madpugger
          • Sep 2007
          • 1901
          After a week of calling Pipex every day to find out whats happened with my broadband, eventually getting through to a second line guy, who put me through to third line support... Oh yes mr sutherland, BT have been looking at it, you need to change your password. Oh, that still doesnt work mr sutherland? I will call you in two weeks when you get home from business... WTF?
          Anyway, for sh1ts and giggles i decided to reset my router (after trying it elsewhere - worked - and trying others here - didn't) and do a line auto test, it said PPPoE... OK, for the hell of it i'll let it try. (No mr sutherland definately PPPoA) bing, got my net back
          Obviously with Pipex being bought by Tiscali, and then by Talk Talk, the setting needed changed but they havent bothered to tell anyone, including themselves... Idiots.
          Back on topic....
          Now I have net I can look for bit again
          So far the list is:
          Head Bolts (Aelred)
          Gasket set (pos Aelred too)
          Clutch, sachs (dunno)
          Bearings (dunno)
          Rods (dunno)
          Timing Chain (audi)
          Got a couple other bits and bobs to do at same time but if you guys want to recommend the person you got your stuff from then feel free
          Le Mans 2012
          Nurburgring 700
          1995 S2 Avant
          • Nuvo
            • Nov 2003
            • 3825
            #20
            It should be set to PPoA VCMUX encapsulation if you are using a DSL modem only regardles of the provider. PPoE is for connections to a DSL modem via Ethernet.
            • madpugger
              • Sep 2007
              • 1901
              Yeah I thought that too, but it's working...
              It has always been on PPPoA but suddenly stopped working. It works on PPPoE with my modem router thing, no wireless, just one Ethernet port.
              Le Mans 2012
              Nurburgring 700
              1995 S2 Avant
              • madpugger
                • Sep 2007
                • 1901
                Originally posted by PaulJ
                Standard audi gasket is an all steel affair anyway, Sachs race clutch cover (707) then a choice of 6 puk or full face clutch, Don't see many threads where people complain about their clutches although not the cheapest but best never is
                Cheers PJ
                Can't seem to find these, 707 as a part number? Although I read in a for sale thread that 707 is for SM Flywheel?
                On the hunt for a good supplier for these in UK?
                Le Mans 2012
                Nurburgring 700
                1995 S2 Avant
                • madpugger
                  • Sep 2007
                  • 1901
                  Oh, PaulJ...
                  I like this one...
                  And while I am posting pics I like...
                  Hope you guys like them
                  Le Mans 2012
                  Nurburgring 700
                  1995 S2 Avant
                  • Sleeper_Avant
                    • 2372
                    Alright mate, hows the hunt for bits going?
                    my A4 belt tensioner let go and done 10 valves, a cam pulley and wudruff key also, yours ok?
                    Euro car parts do valves for about a tenner each if your stuck.
                    any more news on the steel gaskets? new to audi`s so cant comment but is it just ABY or were they in AAN`s etc?
                    Cheers, Sean.
                    1993 URS4 Avant Emerald Green 350+bhp
                    1991 Ford Sierra Sapphire 4x4 in Magenta
                    BoooOOOSSSSSTTTT BANG BANG CHIRP CHIRP
                    • Knight Rider S4
                      • 3541
                      GSF for the head gasket kit £69 ..best price out there and Victor Reinz so same as Audi Kit
                      93 S2 Avant Parting
                      91 URQ RR
                      02 A4 tdi Avant
                      • madpugger
                        • Sep 2007
                        • 1901
                        AFAIK 3Bs and therefore pos early AAN had paper, and ABY ADU and more than likely AAN had steel. Mine is one of the last ABYs and has a factory gasket which is deffo not all steel, there are parts where it is starting to erode the asbestos in the water channels.
                        I got valves from David Falconer Engineering in Aberdeen.
                        I am gonna order a headset from the local factors (Dingbro) for now for the seals etc and use an OE head gasket and ARP studs. When I get the turbo I will use a comp reducing gasket likely from Doug (MRC).
                        The main thing is the clutch and rods. I need to give Aron a shout for rods but need to find a UK supplier of SRE clutch as that will be whats holding me up to get it back on road.
                        I was going to keep it off the road til all the bits were done but all the bits will cost more than i expected!
                        Oh, my cam gear and crank sprocket are ok, although the harmonic dampener is naffed, although i found one laying in the spare room i must have bought ages ago!
                        Le Mans 2012
                        Nurburgring 700
                        1995 S2 Avant
                        • madpugger
                          • Sep 2007
                          • 1901
                          Cheers for that, will give them a try. Dingbro were about £60 but forgot to ask which make! DoH
                          Le Mans 2012
                          Nurburgring 700
                          1995 S2 Avant
                          • istoo
                            • Mar 2006
                            • 408
                            Mike,
                            Will drop you an email, but Peter Chimes at Sitrling Audi is superb to deal with, enthusiast himself and insanely helpful. If only Aberdeen was the same.
                            Hopefully see you next time in mid august
                            • madpugger
                              • Sep 2007
                              • 1901
                              Yeah I hope so Looking forward to the next one
                              Does anyone have an ABY alternator for sale, and a PAS pump pulley?
                              Ta
                              Le Mans 2012
                              Nurburgring 700
                              1995 S2 Avant
                              • istoo
                                • Mar 2006
                                • 408
                                the alternator from my AAN (beleive they are the same) is at Kinghtriders place. It works, but squeaks as wee bit.
