My 3B to RS2 project
Guest repliedBad audio quality, but sounds awesome
Do see what you mean though, my 80 is "just" load enough to be comfortable, without a sterio in, and a tocuh on the quiet side without
My S2 is too quiet at the mo though.....Leave a comment:
Was going to try and fit the extra silencer just in front of the subframe but I dont think it will work without major welding so will probably go a bit further forward in the straight section.
Going to try the dB killer first to see if it affects back pressure for my "overboosting at high rpm" problem, also will be useful at tracks with a dB limit..
Yes it goes in the tail pipe, I'll secure it with a small bolt through the lower edge so it can be removed.Leave a comment:
Why both the DB killer and 3" silencer?
Does the DB killer go into the tail pipe?
Where do you mount the silencer?
My system is loud as hell as well, but I dont drive the car that much. But i think it would be nice to get the volume down a bit.Leave a comment:
It is stupid loud inside the car, I cannot drive it, just get a headache in the first 5 minutes.Leave a comment:
A good result finally, I hate it when these little bits don't work, makes the car feel crap
Still a little bit of water leaking in, so hard to see where it comes from, will buy a new boot for the bonnet cable asap, silicon sealant may not have completely cured it.Leave a comment:
Well done mate! Nice to know all problems get sorted eventually. 4 and 1/2 years though - hope they don't all take that long?
CHrisLeave a comment:
