dyno'd last night. went safe with less boost and timing. and fuel change to E85 with bigger injectors.
615 AWHP, 434 Wtq. not too shabby considering the run was 3rd gear, ~30-32 psi, 8500 rpm. went for fully custom bottom end.
and some vids for ya.
and then pull 1-4.... car jumps. dyno grating moves. fireball exhaust on 1-2 shift. BAM....
Issam built the bottom end;
AZG 06A 2.0L block
billet main caps
girdle
86.4mm forged crank
150mm custom rods with 21mm wrist pins
83.5mm JE pistons
1.74 rod ratio, 1893cc.
Joey (DoubleJ Motorwerks) built the head;
AEB non-ported casting
CAT Billet solid lifter cams, 1003756 (the smallest solid grind, BTW)
CAT solid lifters
under-lifter lash caps
ST inconel exhaust valves, single groove
+1mm ST SS Nitrided intake valves, single groove
ST springs and retainers
CAT cam gear
full valve job, all documented/blueprinted.
Turbo is a Bullseye Power S366XL, T4 divided inlet 1.00 A/R
Brian Macy of Horsepower Connection made the twin scroll manifold and exhaust.
two Tial MV-s 38mm v-band wastegates.
my own thing on the wastegate lines, SS hardline tubing.
3.5" compressor out, 4" v-band exhaust straight out of the fender, 5" anti-surge inlet.
Fueling is E-85, Bosch 1680cc injectors fed by twin Bosch 044 pumps.
the cam card calls for 106/106 and we (Joey of DJM and Collin of Techtonics Tuning) Cam Doctored them; then on the advice of Bob, Pete, and Collin we set it up to run @ 112/112.
lastly, degreed the head and block together for PERFECTION.
conservative tune done by Kevin Black. we had a goal, "dont run above xx psi, nor over xxxx rpm, etc. make it safe, take it to the track, then do some power making.".... we did just that.
AZG 06A 2.0L block
billet main caps
girdle
86.4mm forged crank
83.5mm JE pistons
CAT solid lifters
CAT cam gear
i think i put over 40 pounds of ice in to begin with, and had a leftover 100 pounds when done? only drained water and added ice once? added another 25 pounds the second time? the ice tank was still cooooold 24 hrs later.
