ok then. My AAN 20vt engine has arrived and so I thought I'd start a thread to help me 'check off' what I have and what I don't have for the conversion.. And thought it may also help others planing a similar conversion them self's.
Let me know If i've missed anything and i'll add it to/update the list.
I Have:
[x] AAN 20VT engine (from URS4) (from an auto)
[x] ECU
[x] loom
[x] Harness
[x] standard coil packs
[x] standard inter-cooler
[x] standard Turbo (hot side & cold side)
[x] standard inlet manifold
[x] standard exhaust manifold
[x] 16 row Mocal oil cooler
[x] MAF sensor
[x] New engine mounts *
[x] Custom UR 20valve flywheel *
[x] Sachs performance clutch *
[x] New master and slave cylinders *
Don't Have:
[ ] The slightest idea of what i'm doing
[ ] Needle roller bearing to put into the end of my crankshaft
[ ] 3B or custom down pipe to mate to Typ85-CQ exhaust
[ ] complete set of turbo hoses
[ ] uprated fuel pump
Also, I'm told the engine is from an auto. Will I need anything changing because of that, to fit this engine to my 5 speed manual CQ?
hope some of you can help. never done anything like this before.
I Have:
[x] ECU
[x] loom
[x] Harness
[x] MAF sensor
Don't Have:
,i am about 80% of the way there at present,still a few things to fabricate but think i might have it running within the next few weeks just need to keep finding time to work on it.Very happy with how its turned out so far,will ave to update my thread soon.
Or are you just saying that thos other things will need changing if I fitted the ABY inlet?
