Something definitely still wrong.
500hp is not that hard on 8.0:1 CR on this turbo.
Also, these turbos (GT3076R/GTX3071R) keep making more and more power all the way until they run out... There is no way you are hitting octane limit if your CR is what it is.
I usually run GT3076R's 32-33 taper 30 on 2.2T's. On a 2.5L it should still be able to push at least 30 taper 28.
As for detonation - of course you are going to get detonation at some point if you keep advancing timing, but on 8.0:1 you can easily run 15...22 timing up top if not more.
This is assuming 0.82 hotside of course. If it runs 0.63 on a stroker the results are not surprising in the least.
