Hello all,i've decided to post up my "new" project,for my own motivation as much as anything else
I've owned my 93' aby coupe for a little over a year now,and to be fair it's been one
disaster to the next,here's why...
I bought it last september with the intention of keeping it relatively standard and just enjoying it from one weekend to the next,which went well for all of a month.
On my way home from the shop one night the car died,closer inspection revealed the the crank sprocket had sheared it's key,resulting in 10 bent valves-gutted doesn't describe the feeling
After much swearing and tearing out chunks of my hair i decided to grit my teeth and fix it,two weeks later and all was as it should have been,at least for a while
The car developed a bad tappety noise which was getting progressively worse,also the oil pressure was all over the place.I remembered that while i was repairing the head i had the rocker cover shot blasted and powdercoated,along with my brothers (he was doing an xe conversion on his astra at the time).
To cut a very long story reasonably short,it appeared that there was blasting grit inside the engine,the only explaination i have come up with is that when it was blasted it was not degreased correctly (if atall),meaning the blasting grit would stick to the oil and grease.But hey what would that matter if you cover it in powder coat
So the grit that was washed out into the oil siezed all the lifters solid,killed the oil pump and subsequently totaled the engine
At this point i gave up,binned the lump and sulked for a good few months...until now.
Luckily work has picked up a lot this year meaning i now have the money to get this mess sorted out once and for all
I have an engine on it's way and have started to collect a few choice upgrade parts:mischeif:
The spec is to be determined at the moment but want to be somewhere near 400hp with as much torque as the stock rods will safely handle.
This is how it is at the moment
more piccies to follow
