This is the car of a friend of mine. My job is to build and install the engine, gear train and electrics.
look what i found in my yard!
Tags: None
Good eyes you have!!!
You are right..is impossible to work on that hill..but that is only the path to the garage. The car is already in there.
I will make some pictures later...
All the best!Comment
slope leveled!
Looks like a really nice paint job!
You can see some cracks in the paint...on the fiberglass panels. But..is ok..dont know iff those cracks are caused by poor paint preparation or something else. I want to pe prepaird for my own car. I hope at mine i will not see something like that.Comment
Maybe the fibreglass was painted too soon and not allowed to cure or the release agent was not cleaned off properly, you should paint the other side of the panels too with flow-coat (sp?) so you don't get the damp coming through from the wheel arches. You need plasticiser in the paint so its a bit flexible..Comment
hmmm...i think the paint..dosin't have all the necessary stuff inside for the fiberglass.
or is just in the places where the fiberglass part can moove too much. We will see how it looks like after few weeks.Comment
I have started to put together the front suspension and i have a question!
I bought for this car the front s2 hubs. The ideea is, i can use the same coupe quattro driveshafts? I dont want to mess with the gearbox side. Iff yes...please tell me what wheel joint should i use to have the same splines as the s2 hub and same fitting system....is with an safety clip inside the joint...not with expandable clip like s2.
Thank You!
EugenComment
Is that car imported from sweden?Comment
No...was a quattro coupe from 86, red colour original.
Registered in Romania since long time ago.
Ok, I want it anyway=)Comment
I imagine soo...
For my coupe i used the old 200 hubs...dont know iff the shafts at coupe quattro are the same with mine ones wich were from FWD coupe.
I will try to find some.Comment
