UrS4 2.2T Avant project
  • david1980
    replied
    any update to this?
  • Schumacher_R
    replied
    Good job!
  • Spyform
    replied
    Whats up?
  • rxl
    replied
    stock flywheel the single mass one has a disbalance of 27g.
  • Acki
    replied
    Somewhere I found the information about the external imbalance of the stock flywheel. May this cause some issue with balancing everything to zero.
  • PRY4SNO
    replied
    Originally posted by Thuppu
    Pending time and motivation
    Godspeed, friend.
    Time, will, and pockets able; which don't often reside in time together.
  • Thuppu
    replied
  • Tom_
    replied
    Any updates Thomas? Seems to quite a while
  • PRY4SNO
    replied
    Originally posted by Prosac
    Hi Thuppu, have you balanced your 2.5Tdi crankshaft? Should you balance them IMPERATIVE? I have already heard that there are various 2.5L with AEL block and 95.5 crankshaft where nothing was balanced.
    It'll run, but you'll be surprised how much work it takes to zero balance your diesel crank when you get around to it. If you can't zero balance everything at once, wait until you can. And proceed with a measure of caution.
    Just my 2 cents.
  • Kiku
    replied
    What dry sump pump will you be using? If you have thought about that?
  • Thuppu
    replied
    Hello! No, I have not balanced it, but of course it would be a good thing to do.
  • Prosac
    replied
  • amarider
    replied
    Originally posted by KTM-Mike
    Thuppu, I have some trigger-issues with MaxxECU with stock Audi-sensors.
    What "trigger arm voltage" & "home arm voltage" and other settings are u using ?
    Have u changed some of the values ??
    Sorry for hijacking your project-thread.
    Very nice project
    /M
    what ever happened here? We are struggling to get cam position sensor to read on Maxxecu. The flywheel sensors look fine. Someone saying we should try 12v(input) hall sensor?
  • Thuppu
    replied
    Dry sump kits ready for install...
    replied
    Lovely engineering as always
