Let the spending begin.....
  • twenty valve
    • Oct 2010
    • 630
    even if you don't change the steering rack, at least change the gaiter (£4 from GSF) and check the condition of the damper. Both where screwed on my avant.
    The damper moved in and out with no resistance which certainly would have been noticable when hitting bumps!
    • Starscream
      • Feb 2009
      • 109
      #32
      I need help with the piston rings. Ive phoned pentraeth and they say that its 81 for standard and 82 for a reborw :-S mine have 86.08 like ive said, so where can i get the ive given Quattro corner a ring aswell but nol luck! Help
      • nip
        • Apr 2006
        • 1786
        • Home: United Kingdom Current: Abu Dhabi
        #33
        it dont say 86.08 look where the decimal point is its 80.98,
        • Pirvu Eugen
          • Apr 2007
          • 1978
          • Country: Romania
          #34
          Nip is right! These engines have 81 mm bore. Not 86. First overbore is +0.25mm, second is 0.5mm. The piston mark is 80.98.
          • Tap Towers
            • Dec 2010
            • 220
            Stand on the otherside of the block, and look at the numbers again...
            05 Allroad
            05 Seat Alhambra
            • twenty valve
              • Oct 2010
              • 630
              Have a look at totalseal piston rings
              If It Takes a Piston Ring, We Can Build It! Since 1967, Total Seal has been the authority in piston ring design and technology for Vehicle, Diesel, Industrial, Marine and Aviation applications.
              Thats what I'm going for. Heard alot of good things about them. Especially for boosted engines
              • willg54
                • Jun 2009
                • 2055
                love it!! and it took us this long!!
                1996 Audi S2 - 295bhp and 326lb/ft - Complete Rebuild Project
                1994 Audi 80 - 2.0 8v (slow but reliable!)
                • Starscream
                  • Feb 2009
                  • 109
                  #38
                  Ah ha! so it is 80.98! Nah what it was the engine builder wrote down 86.08 on a piece of paper but then said he never said that that he'd written 80.98, now i can read numbers and went over tonight and it is 80.98, new piston rings please sir....
                  • Starscream
                    • Feb 2009
                    • 109
                    #39
                    Thanks Aronmatic! and yes ive got 5 of them.
                    A very dirtty sump, with thick oil, ewwww
                    Not sure wether to piant the block or leave it bare and which colour if i do paint it, im thinking black.
                    Box of Bits, anyone after and 3B/ABY inlet?
                    Do stock ABY conrods fit the 1.8T and are they a cheap upgrade for someone?
                    • Starscream
                      • Feb 2009
                      • 109
                      #40
                      Havent updated this in a while now, Clutch has arrived, So ill be able to send the crank away for balancing
                      Will have a lot of fun trying to fit this
                      All the other small bits such as the ARP Bolts, shell bearings, belts, valve guides etc have all arrived aswell.
                      So soon pictures with all of theses things in place.
                      little sneak peak on the engine alloy parts, sandblasted and painted anthracite
                      • Starscream
                        • Feb 2009
                        • 109
                        #41
                        Now that my inlet manifold has arrived (thanks raymor) i have some questions and i have trued the search.
                        What do i need to fit a AAN manifold to an ABY since its only the throttle that will fit im guessing i need a fuel rail any other small bits?
                        • Starscream
                          • Feb 2009
                          • 109
                          #42
                          A little update, ive had the crank back from basset down all balanced up so the engine will be going back together soon and hopefully turning the key by next month.
                          After all the bits ive bought will it be safe to start the car on the standard ECU or should i be looking for a homefried one? Or another option?
                          And also Ive invested in a custom cage and fia seats, its heading for the track me thinks! And secondly whats cheaper/better DIY coilovers with bilstein inserts or KW coilovers from the likes of 034?
                          • terrybullwon
                            • Mar 2006
                            • 8782
                            KW's from Carsten Wagner
                            Chef
                            • s2_bo
                              • Oct 2005
                              • 6067
                              #44
                              Or you can make your own CCK's out of a kit that Mance sells using Bilsteins from an urs4 and Eibach springs.
                              I had this set up and its rock hard, not so fun on bumpy roads as its not forgiving at all..
                              Costs just under a grand all in with the top mounts.
                              91 S2 coupé - RIP
                              98 S8 - Luxury barge
                              • s2_bo
                                • Oct 2005
                                • 6067
                                #45
                                p.s. if your running stock FPR and Injectors and timing then its fine to start it on the stock ecu. Its a good idea to run it in for a thousand miles before you turn up the power anyway..
                                If not then it will need fuel and boost maps to suite what ever is on the car.
                                91 S2 coupé - RIP
