Spikemoto,
Thank goodness you got a better camera.
Not sure why no one has volunteered a possible cause.
I can't really other than to make to naive comments, I presume it is not the ignition switch behind the key?
Also with my limited understanding, and I know you've replaced the MAF, but I thought the MAF didn't like cone filters because of the oil drawn out of them. I know the wires in the MAF heat up to burn off contaminants, but maybe they can't deal with all an oiled cone filter might give compared to a oem paper element in an oem Airbox?
Hopefully others with more experience will post their more informative / accurate suggestions.
The shop spoils you, makes it easy for you. Not jealous at all from my wet cold gravel driveway.
What I really posted for was to suggest changing the orange turn signal bulbs to chrome finish to loose the orange reflection inside the lamp housing. Also to blacken the chrome rim of the bonnet grille, it'll look good, especially on a white car with black rims.
What suspension ?
And also maybe post a side on and three quarter angle shot from the front and the rear to show the car's stance, which looks just right.
Best wishes for a definite cure with the cutting out.
Kind regards.
What suspension ?
Kind regards.
