the last conrod, the 158mm,i had i little discusss about them,so they have 23mmxbolt....i have these at home,for the audi...they are one year allready,so i will fit they in the block this summer..i will bore the 2,4 dieselblock from 79,5 to 81mm,then its "stock" bore....
ACQ Endurance Racing car project, 405HP, 539NM
Henka, how is it possible to use on a stock 2.2L block and crankshaft 158mm long conrods with a piston's compresison height of 34mm?
OEM conrod is 144mm and OEM compression height is 32.8.
With the above setup piston will go some 15mm above deck at TDC!!
MarcoComment
Hmm.. Okej, I did not know the stock height, sorry. I just figured that when he said that they were supposed to be used with those pistons he knew what he was talking about. Apperently he didn't then.
I see your point. It puzzled me at first but I didn't really think about it. He must have been pulling my leg. I'm gonna have to ask hem again I think.Comment
i think so......the tall deck are 236mm and the low are 220mm.he ment the tall block,when he ment the stock block,with stock bore...81,oo on the 2,5 eurovan dieselsComment
Hi Henka,Originally posted by HenkaHey I just realized - it must be with a tall deck! That way they'd work!
Thanks for checking into that!
I'm about to head to bed but wanted to log on here and check what you posted. Turns out my work has blocked access to "discussion forums and boards", so I can no longer follow these threads during the weekday!
But that's okay tho', because I think I'm getting more done now!
I wonder if there is any interest in a group buy on these rods. They are already more affordable than just about any other alternative I've heard of.Kenneth
1990 Coupe quattro
1991 200q20v x 2
1985 4ksq 20vt project
1986 Coupe GT 10vt project
2006 Honda Ridgeline
1998 Honda VFR800FIComment
Sorry, ears just pricked up then... Will these rods fit a standard ABY motor. If so how much are they and yes I'm interested in the group buy at the right priceOriginally posted by auditudeHi Henka,
Cheers ears
Karl
OzOct 93 build MY 94 ABY Kingfisher Blue Audi S2 with MD147 turbo :mischeif:u SOLD
Audi 90 Quattro 20V 1989 7A
Audi TTRS 2010 APR stage 2 +
Triumph 675 Street Triple RComment
SPM has rods that fit stock IL5's. 144mm long (stock 7a/ABy/3B/ADU/AAN....). They are 1225 SEK per rod. This is including swedish VAT which is 25%. Without VAT we are down to 920SEK, which is about €110 I think. Sten at SPM said that in a group buy he could cut the price a bit - I did not ask how much and he did not say. Group buy for him means more than 4 sets of rods.Comment
I am bit confused (maybe it's late...). Are there tuners offering dieselblock conversions (with the use of parts from B3/ABY, like the cilinderhead)? Or are people of this forum calculating the possibilty of a dieselblock conversion (or perhaps a bigger bore or stroker kit with the original block)?
I do know that KRB is driving a 2.5 quattro. From what I have heard with several other marks (VW and Opel) tuners use dieselblocks because they are very strong to begin with, especially the block and crank itself...Comment
Hello,
I'm selling stroker kits for stock 5cyl 20v engines(3b,aby,aan...), or for diesel block too.
from bore size 79.5mm - 83 mm.
Pm if interested.Comment
