Another SWB Quattro project...maybe S1....decision pending
  • Tonks4x4
    • Nov 2005
    • 3062
    Yes the old ones are way out! However it was nice to see on the factory tour at Ingolstadt that all the panel work is now laser measured by the robots in manufacture to make them far more acurate.
    Audi Nut!!!
    • Billman
      • 4129
      Q; Are the Gearbox/diff/legs/suspension and subframes the same between the S2 and the V6 coupe?
      Go Holset or Go RS4
      • A80Avant
        • 10873
        • Country: Greece
        how many cars are you going to buy and brake in order to make this quattro?? haha
        • Billman
          • 4129
          2 maybe 3?????
          Go Holset or Go RS4
          • keepinthedreamalive
            • 96
            A while back on ebay there was a guy who would loan for 12 months a jig that would bolt on to the front and rear subframe mounts, then you cut the 320mm out and then slide the rear end up the jig to weld to the front.
            It had some real good photos and looked really simple to use, as all the best ideas were.
            Off the top of my head, he wanted only £500 for a 12 month loan, which seems a bargain when you think of the work it would save.
              it would not be hard or expensive to make that kind of jig to be fair, certainly less than £500
              • Billman
                • 4129
                #22
                yes but transport would be an issue since I am in Greece
                Go Holset or Go RS4
                • Billman
                  • 4129
                  #23
                  Go Holset or Go RS4
                  • pasbogdan
                    • Sep 2009
                    • 1160
                    • Country: Romania
                    #24
                    v6 box is 01a.I used 01a on my aan s4 with 1.5 bar boost peak(stock turbo/injectors) and not made any problem.Maybe someone will tell us how much 01a will hold.
                    Anyway,prop is longer at 01a 5 speed than 01e 6 speed.Again maibe someone will tell us if 01e 5 speed is shorter than 01e 6 speed.
                    Hubs are not the same..
                    • Billman
                      • 4129
                      #25
                      the back diff?
                      Go Holset or Go RS4
                      • Billman
                        • 4129
                        #26
                        anyone knows if the 80 Typ 81 quattro 4 door or 2 door has the same floorpan as the Typ 85 Quattro?
                        Go Holset or Go RS4
                        • quattrostyle
                          • Oct 2006
                          • 6229
                          AFAIK all quattro's should be type 85's anyway the floorpan is the same yes.
                          • Tonks4x4
                            • Nov 2005
                            • 3062
                            I don't know about other 2 door quattro's but mine has a Typ81 chassis number
                            Audi Nut!!!
                            • quattrostyle
                              • Oct 2006
                              • 6229
                              might be different for the 2-door quattro's. Interesting to know if the first urq's have a 81 or 85 VIN
                              • Billman
                                • 4129
                                #30
                                The Coupe GT 1800 was today on the scale and it made 900kg!!!
                                Go Holset or Go RS4
