the cranc in 2,4d and 2,5tdi, and in the 2,5 10v(petrol) and maybee in the 2,6 5 pot have the 95,5 stoke.... the 2,4d and the 2,5 10v(petrol) and maybee the 2,6 does have the same cranc.... the 2,5tdi cranc does fit in the block, but does NOT have the same P/N.. beacuse the steeplate for the timing in the last throw...
the 2,4 and 2,5 10v(petrol) does have the 150x24 conrods.. and the 236 mm block..2,4 have the 79,5 bore nad the petrol 2,5 10v have the 81,00.. and deep pockets in the piston. 8-((
the 2,5 tdi block have the double strength outside, and the 2,5 marks at the first syl, and 150 x28 conrods..., and 81,00 bore
the sylinder WALLs are about 6,1-6,3mm in the 2,5tdi blocks
no prob to rebore to 82, or 83..
the 20v head vill fit with minor weldin in a corner, to cover the gasged, and to rebore the headbolt holes
The 92.8mm only comes in the 2.5 Petrol SA T3 Transporter. Nothing else got this crank
The 2.4D from the T4, the 2.5TDi, the 2.5 T4 Petrol and the 2.6 Petrol SA T3 all share the 95.5mm crank which will work, but requires one off pistons to work with the 20V head.
but requires one off pistons to work with the 20V head. LOOOTS of people have built "the stroker" with pistons here att this forum.. all the conrods fill fit from 5 pot... fx 158x 23 or the 159x20 or similar..the Turboverson or some the N/A versons...
