so after a return journey on a flat bed we have started to disassemble and confirm cause of sparks inside bell housing one off the most unsettling sights to come from the timming hole in bell housing ever i am sure
we have started removing engine as new clutch was on cards and really wanted to get in and pull out the engine with help from friends to get a good understanding of how this car is constructed pics included unfortunately only a couple as the guy in the images will be finishing up when i am at work
so work to undertake on this occasion is cam belt and clutch oil plugs cap arm leads.
starter motor would not engage so was unsure due to sparks if clutch had disintegrated and jammed the throw or starter motor got stuck and burnt out turns out neither but both at the same time sort of
this is the starter motor
and also if some one could shed light as to why there is a tap in the hose it was in off position and i can not understand why it is there
i will order clutch flywheel combo from 034 and will build block before the shell so will await call tomorrow i have had a unit offered to me 200 yards from this one big enough for two cars so will be possibly going in there.
