ABC coupe
  • martinjs
    • 3205
    Originally posted by Error404
    A nice tight rear end makes as much of a difference as doing the front IME
      fact
      • marathontom
        • Jan 2011
        • 232
        Bolted everything up yesterday ill get some better photos tomorow as the subframe looks the dogs!!! And I'll get some comparisons of how the car sits after I've cleaned it
        • sidrick
          • Jan 2011
          • 1342
          Looks great
          • marathontom
            • Jan 2011
            • 232
            Freshly powdercoated subframe, wishbones, ARB, hubs and struts. New "sports" shocks and 40mm springs. New wheel bearings, drop links, ball joints and top mounts. Pollybushed wishbones, ARB and bambridge solid mount subframe. All mounting hardware gold zinc plated and new stainless nyloc's throught out
            Fronts not quite 40mm but I think the original suspention had sagged and the new stuff needs to settle. Need to get the tracking sorted on Monday but it handles like its on rails! Little harsh but proper positive, eliminated the tugboat like body roll almost completely!
            Excuse the filth, some rims needed now.
            • marathontom
              • Jan 2011
              • 232
              So this morning this greated me as I walked through my front door. Not a great mood setter for a Monday morning I can tell you.
              Properly gutted after the recent time and effort I've invested in the old gal. Alas I wasn't going to bow down and let spineless, scumbag a'hole's, that go around doing this sort of thing, beat me and win!!!!
              Tom and polishing mop - 1. Fu*ktard - 0.
              If you were properly looking or I pointed it out you'd still see the scratch, which is more of an impression in the base coat I think. It's on a panel that's been re lacquered at some point so I didn't wanna go crazy with the mop and burn through. I think the amount of wax I've been applying recently helped a little to haha.
              I won
              • targus
                • Sep 2012
                • 185
                • Home: United States Current: England
                #82
                people have no respect for other people's stuff. Glad you got it sorted, looking good.
                • Drummer87
                  • Oct 2009
                  • 1644
                  • Home: United Kingdom Current: Scotland
                  #83
                  Stunning picture !! The last one
                  What ****ing *******s!!! No sense in value till it happens to them. What comes around goes around
                  • marathontom
                    • Jan 2011
                    • 232
                    a set of coupe quattro speedline wheels got dropped in my posession today....... For free
                    As you can see there's a reason they were a little on the cheap side, all of them are pretty shagged but I think I can make the work for me.
                    Had a quick go at polishing the lips to see if the corosion was going to be an issue.. It's look like its not
                    • Drummer87
                      • Oct 2009
                      • 1644
                      #85
                      Flipping the bird at wheel!!! Classic
                      • Acidburn
                        • 13459
                        What method did you use to polish the lip up?
                        The allen key bits do come off as they are only stuck on from what I have seen.
                        • quattrostyle
                          • Oct 2006
                          • 6229
                          They are also not any sort of metal AFAIK. Should be able to pull them out I believe, but will they remain in one piece? I doubt that.
                          • marathontom
                            • Jan 2011
                            • 232
                            I removed the flaking paint and the white powdery corosion with a brass wire wheel drill attachment. Then 250/400/800/1500 grit sand papers with wd40 by hand and then I used a cheap polishing wheel kit I brought from eBay a few years back. It has 3 wheels (course,med and fine) which i used on a drill with a couple of compounds and some lime powder. That little section took me about 15min at work whilst my boss wasn't looking so it's not crazy labour intensive as people make out.
                            The bolts I thought were plastic are actually alloy. I hammered a splined socket onto them and twisted them out without any problems. There not threaded in but have burrs on and are pressed in.
                            • marathontom
                              • Jan 2011
                              • 232
                              Well.... That's the end of an era. Almost 6 years of ownership and about 9 years of it being in the family. The coupe is now dead. Really going to miss that old girl.
                              • Bowie69
                                • Nov 2013
                                • 2675
                                That's very sad, guess it is just not worth repairing...?
                                On a lighter note if you want to sell your 6-spoke speedlines I may be interested
