Project Zombie - 3B back from the dead
  • SteveH
    replied
    Well the jaded laser red paint is a thing of the past...
    Tailgate and trim should be finished by the end of the day.
  • re2500
    replied
    In that case keep the pics coming
    Im MOTing before the end of the week, 4 wheel align and then cambelt change. A quick wash and polish and ill be ready to tax at the beginning of Oct ready for ADI.
  • SteveH
    replied
    The car will be painted tomorrow and flat and polished by the end of the week. I'll then stick it on the ramps to fab the exhaust from downpipe to rear box. I'm aiming to have it back together within a week and off for it's MOT.
    ADI shouldn't be a problem, however I've still got to sort out a running issue, do a cambelt change and think about doing the ECU and pin swap.
  • re2500
    replied
    Fair play, your bo77ocking on with it! This making an ADI appearance, or is that a tad adventurous?
  • SteveH
    replied
    The car is now stripped for painting. It's frightening what you find hidden under solid looking paint
    There was corrosion starting around the mounting holes for the rear lights and around the bolt hole in the rear quarter for the rear window seal. There was also corrosion starting under the trim that runs down both sides over the doors and windows. The worst thing with this type of corrosion is that you can't see it happening from the outside, so you could be oblivious to it until it's already got a good hold. Glass out is a must and a lot easier than I thought it would be. Three good coats of PPG Laser red 2K to go on this week and then a flat and polish.
    The challenge will be getting all the trim back on without scratching the paint.
    Thanks to the lads at Restomod who put in some hard work yesterday
    replied
    it's easy when it's not your car and you're not the one holding the spanner Wasn't it cylinder 3?
  • SteveH
    replied
    AND...big thanks to Rusty for the support getting a stuck spark plug out
    I have no idea why plug number 4 was almost seized in the head. I thought I was going to break it or strip the threads getting it out. There was no sign of any issues with the head or threads on the plug when we got it out
  • SteveH
    replied
    Yes Greg, the Sachs clutch is in. It's a heavier pedal than my old unit but the engagement isn't too severe. It's not bedded in yet, but feels good
    Can't wait to give it some stick! I started her up yesterday with only the downpipe on I'm going to run her on the 3B RS2 setup until I can get it mapped with the ABY ECU, COPs and EV14's.
    This is the layout for the PAS and alternator. I've got a shorter V belt to avoid running close to the alternator adjuster. Hopefully the single belt will be able to take the strain of running both systems
    Test fitted the radiator and fan today, but have decided to get a bigger fan before connecting up the coolant lines. Into the paint shop in 10 days so I need to get the glass out next week. Plenty still to do for ADI...
    Phone pic, I'll get some better fitment shots tomorrow.
    replied
    Did you fit the sachs race clutch this time around? Making pretty quick progress now aswell
  • SteveH
    replied
    Originally posted by cab9fab
    The bay is looking great. I like the black intake/valve cover making the red coils pop.
    Today's fun and games has been finished off with refitting the clutch slave, what an absolute sh*te of a job. I've done it once before under the car and was prepared for some agro, but it was worse than I remember I eventually got it in place after soaking myself in hydraulic fluid and realised the bolt I had to hold it in place was the wrong one I think the thread in the gearbox is slightly stripped, so I'll remove it and tap it out larger when I have the car on ramps. The new Sachs clutch is quite a bit heavier than the old unit. Definitely one to build your leg muscles in traffic....
  • Wheeljack
    replied
  • SteveH
    replied
    Originally posted by sidrick
    Loving this write up.
    How were the handbrake cables to do? I've a pair waiting to go on mine
    The cables weren't too bad, but I'd already removed the exhaust which was a real pita to get off. I had to resort to using a hacksaw blade held in hand to slowly cut through the exhaust joint bolts that are right above the rear driveshaft Once the exhaust is out of the way, it's just removal of the heatshield to get at the handbrake lever end and the rest is just a pull out job. I got Pagid cables from Euro car parts and whilst they have the right end fittings they are missing a couple of bushes where the cables run through mounting points. I just pulled the fittings off the original cables and transferred then to the new cables. Surprisingly my calipers weren't seized after 6 years stationary!
    I'd take pictures, but I'm working on my back under the car on axle stands with sh*t falling in my eyes, so the camera didn't come to mind
  • sidrick
    replied
  • andy10v
    replied
    Coilpacks match your paint
    You really do learn to hate Audi rear callipers!
  • SteveH
    replied
    I ordered new knock detectors from Euro Car Parts. Due to the supplier sending an incorrect part, I ended up with three of the green sensors free of charge
    I've also refurbed the rear calipers and replaced the handbrake cables. Another fun job ticked off the list
