Project Zombie - 3B back from the dead
They'll probably look a little less wonky when I get the exhaust mounts sortedLooking fantastic, Steve. Good work.
I actually like the DTM tailpipes, they are a period feature. It's a shame Scorpion made them all wonky though.
It's a shame you don't still have the Porsche Cups. I wouldn't part with mine, even if they are relegated to winter wheels.
The rear box isn't sitting right which makes it look worse than they actually are.Leave a comment:
It's a shame you don't still have the Porsche Cups. I wouldn't part with mine, even if they are relegated to winter wheels.Leave a comment:
Ah! Well you could go to the ecu connector and pop out Pin 36 on the 3b I beleive. That should duplicate removing the connector from the MFTS. It would need to be repopulated if you desert the 3b brotherhood anyway.Leave a comment:
Mike, I'm running the 4 puck sintered also. I'm used to it now and it's not savage at all. Bite is high on the peddle, so I'll try a little adjustment on the master cylinder pushrod.
What's yours like?
SteveLeave a comment:
Hi Robin,
Agreed, the MFTS may be the culprit. With the reversed manifold and radiator on an angle it makes getting at it rather difficult. Probably a rad out job
In the absence of any codes, perhaps the MFTS?
Not sure if just pulling the connector off is the correct test!Leave a comment:
Halfway down here Martin....
There is a reply from the man himself, with pic.
Btw Steve, Yours looks good
Noooo
Missed that thread.Leave a comment:
Looks really good Steve.
Now all we need is Mark H to resurrect his from its hibernation. Does he still have it?Leave a comment:
