Project Zombie - 3B back from the dead
DIY most likely, but looks to be well constructed and nicely slotted. I came off a motor which was running 500+Leave a comment:
Where did you pick up the inlet? Is it a branded one or DIY? Worth giving it a good once over, as they need to be done right!Leave a comment:
I just went for the Febi BMW item. Picked it up off eBay. Not as substantial as the OE item, but the bearing in mine was noisy. The original rubber was actually ok and wasn't ripped/perished after all these years.Leave a comment:
or use the bolts at the back of the head for the rocker cover like the 10v's doLeave a comment:
Looks like a busy list Steve, out of interest where did you get the centre bearing for your prop from?
Look fwd to seeing it at ADI!!!Leave a comment:
Thanks! I will have a think about the earthing if there are likely to be issues. I could always drill and tap a new hole on the head, rather than use the earthing points on the inlet.Leave a comment:
Looking good steve, the spacer will give you earthing issues though, btdt in the pastLeave a comment:
Spring update....
Car has been off the road since the back end of 2014 waiting for me to get around to changing another gearbox. This WILL be the last 5 speed box I replace and it will have to be a 6 speed conversion or something stronger
While the engine has been out to replace the box and check the clutch, I got around to doing a few jobs which have been overdue for some time.
3B Head has been replaced with a ABY head. Took weeks to strip, clean and lightly port.
RS2 manifold has gone and been replaced with a tubular jobbie.
Reversed AAN inlet has been replaced with a dual plenum alternative. Mainly to allow me to go back to the standard location for PAS pump. Addition of a phenolic spacer.
Refurbished the propshaft with new bearing and cleaned/greased CV's.
Replaced inner tie rod bushed with Bambridge items.
A general tidy up and check of cables in the engine bay and replacement of any dodgy connectors.
New braided turbo oil and water lines.
Change or cam cover colour to freshen up the bay.
Still to do....
Fabricate new downpipe, Fabricate air inlet to turbo and output piping to intercooler, Mount and plumb in new oil cooler, Fabricate bases for my new seats and get centre sections recovered in black alcantara, Remove dash to replace heater matrix and get it flocked, Recover headlining...
Other stuff I've forgotten
Target to get her back on the road is August and looking forwards to ADI
Pics to keep you interested!
Picked the calipers up with some simple brackets from lance on forum (Recall). The brackets are 40mm x 15mm ally bar with two lots of holes for the caliper and the carrier. I have a cad drawing with the dimensions. Really not sure which direction to go with the turbo. Possibly Holset for 550-600. More than likely journal-based whatever it is to keep costs low with water/meth for a bit of extra protection.Leave a comment:
Did you make brackets up for the 18z? I did not realise you had an ABY head.
Whats the next turbo going to be?
Sounds like you have enough plans to keep yourself busy anyway.
Calipers are Cayenne 18z with 350mm S5 disks. Cam sensor will fit the ABY head, I will just need to find out what wires correspond to the 3B dizzy sensor. I'm sure someone on the forum will know
The car has been running 400+ for a while now, so I thought I'd check the big ends and mains for signs of wear. No nasty noises or low pressures presently, but best to know what might be going on down there. I'm also thinking of pushing the power to 500+, so would like to know all is 100% before I upgrade. I'll probably stick some ARP mains bolts on while I'm at it.Leave a comment:
I like the front brakes, calipers look bad ***!
What calipers did you go for?
How are you going to add the cam sensor?
Any reason for the bearing inspection?Leave a comment:
Hi Sal, I have loads of pics from the early days. Not sure about the rolling road day. I will check and see what I can dig up.Leave a comment:
Have you got any pics of the printouts from that 1st rolling road day in Luton?Leave a comment:
