Project Zombie - 3B back from the dead
  • SteveH
    replied
    No, I just used a rubber sanding block with some fine wet and dry paper. It needs doing again as I want to add a large AN fitting to the cover. I might try powder coating it this time as the crinkle paint does chip over time.
  • phillip.ps592
    replied
    Was the cover machined after it was painted?
    Sent from my SM-G930F using Tapatalk
    replied
    Well done steve, some good work on there.
    Originally posted by SteveH
    Had the bushes at least 10 years. They have changed the design a few times and they now have nylon washers on the outside of each bush. If you don't have this version contact them and they will replace FOC. Great service and very quick turnaround. Must say I am impressed by them.
    Will post a pic of the breather setup. It's a test unit, so not particulary sexy in its appearance
    I changed mine about 8 times trying to solve the squeaks with powerflex and they updated the designs. Mine arent too bad now but still get the occasional squeak over speed humps
  • BLAMM0
    replied
    Cool thread, enjoyed the pics and the work done, keep going!
  • SteveH
    replied
    My original set had no grooves, these were swapped out with Powerflex within 12 months for a revised set with grooves. 10 years later I've swapped them again and the latest set have no grooves, but have nylon washers on both sides on the bush, rather than just on the outside surface. I don't know whether these are planned modifications or ongoing beta testing based on customer experience/feedback.
    I've just stripped the rears (pressed arms with the purple bush material) They weren't making any nasty noises, however upon inspection, the stainless steel center section has some galling on it. I will let them know and see what response comes back.
  • LHD_Kid
    replied
    Originally posted by Error404
    Are you tracking it Steve? Be a good test for your breather
    I'm sure my Powerflex do have the nylon washers. Maybe they just need more grease
    Some versions have grooves machined into the outside face of the central bush to help hold the grease inside. Also with the nylon washers.
    When I bought mine (around 10 yrs ago) one set had grooves and one set didn't. I machined in the grooves and tbh never ever had a squeak out of them at all... ever...
    replied
    Looks good
    replied
    Tidy!
  • SteveH
    replied
    Any pics of your breather setup? Need to sort mine out over the winter
    Here you go. As I said, it's a bit of a work in progress and was knocked up quickly last week for the track sessions at Combe. I have ruined a MAF recently with oil that had come through the breather system and gathered in my inlet piping and then dripped onto the MAF film.
  • SteveH
    replied
    Yes, I will do at least one track session. Car is running very well atm, so I'm hoping the new geometry setup will make it feel more stable on track. I have 4.2 degrees castor and 1.2 camber on the front at the moment with a little toe in and it feels great.
    replied
  • SteveH
    replied
    Looking forward to seeing it Steve
    How long have you had the Powerflex in? Mine creak pretty badly, been on the car a few years now though.
  • SteveH
    replied
    Originally posted by Rusty
    Lucky you got all that done, otherwise you'd be really busy over the next 36 hours...
    LOL...Lesson learn't today. DO NOT loan your prepped car to your son a day before it's due to be at ADI. One broken driveshaft later and we're back on the road for Saturday
    replied
    replied
