S2 3b project
  • stocious
    • Jul 2012
    • 838
    S2 3b project
    im going to start a thread here as i have just removed my engine and over time will be bringing her back to her former glory and some :mischeif: . as of now the engione is being stored for a while as i come up with a plan/price/suppliers list, with wich im hoping i can get help here with because i havnt a clue where to start. the goal is new rings, bearings, headgasket ect .. ect.. also a head overhaul, guides and VSOS. will start uploading pics as i make progress on car and cleaning engine bay in the meantime. and also going to have a go at a COP conversion whilst i have engine out.i will be asking ALOT of questions as its my first such project. goal is 400 + hp.
    1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
  • Rocco
    • Aug 2007
    • 6393
    • Country: Spain
    You'd need at least a k26/27 then...
    Good luck mate!
    • stocious
      • Jul 2012
      • 838
      thanks rocco. its going to take some time, and $$$$ . found long list of things that need doing while the engine is out..
      • stocious
        • Jul 2012
        • 838
        What do people recomend painting subframes with? going to remove front one tomorow with the intention of getting it blasted. Also is ebay the best bet for poly bush's whisbone one are nackered, or is there a better deal elsewhere?
        • SteveH
          • 4460
          Good luck with the rebuild
          You'll need to set some goals and draw a line under what you will and wont tackle on this project. If you don't, you'll find it will snowball increasing costs and time the car will be off the road. eBay can be a good source of materials, but you will probably find items like bushes will be best purchased through direct sources to avoid the really cheap and nasty imitations out there!
          91 Modded 3B
          14 A6 Avant Black Edition
          • s2driveruk
            • 12696
            good luck and expect at least a couple of discoveries you weren't expecting with a car of this age!
            1992 3b S2 Coupe
            • stocious
              • Jul 2012
              • 838
              Cheers guys. I did have a step back and think again moment, going to clean and paint subframe whisbone's struts and hubs for now and re-bush the front, and then go from there. will post pics soon
              • Rocco
                • Aug 2007
                • 6393
                • Country: Spain
                Will you sandblast those parts?
                • stocious
                  • Jul 2012
                  • 838
                  Thats the plan Rocco, but for now i must find a local place to do it and get paint and bushs's. while taking subframe off i found black anodised alloy mounts so thats nice!!
                  • stocious
                    • Jul 2012
                    • 838
                    Ive been very busy with trying to find job and life crap.. and yester day i finally found time/money o get a few bits blasted and zinc'd. ive given him my fron subframe, struts, rollbar, and brake caliper carrierer's. good family run buissnes who restores cars and had a toyota twincam on a rotating dolly being seem welded, well impressed. will post pics of bits when i get them, also does anyone have the part numbers for front wheel bearings for a 91 s2, and the steel bands that are fitted behind the bearing? there almost like a collar with a whole in it for the abs sensor, have no idea what there called sorry.
                    • irishs2
                      • Apr 2009
                      • 2455
                      The front wheel bearings are SKF BAH-0011 AB, (Audi part number is 893 498 624E)
                      I got mine in cork, from general bearing and seal, using the code Premier BRT1037 which is their pack code for the BAH-0011 AB (I think BRT1036 is for rear coupe)
                      Also: http://www.s2forum.com/forum/showthread.php?t=26872
                      And is it the abs ring you are looking for?
                      Also.. pics
                      Eric
                      95 S2 Avant under rebuild.
                      • stocious
                        • Jul 2012
                        • 838
                        I got mine in cork, from general bearing and seal, using the code Premier BRT1037 which is their pack code for the BAH-001 AB (I think BRT1036 is for rear coupe)
                        http://www.ukpartsdirect.com/catalog...reluctor-ring/
                        cheers eric, thanks for the reply, i will contact them about the bearing's, i was also thinking reliance bearing but i will try your suggestion first. as for the other part, no im affraid its not the excitor/reluctor, i will post a pic tomorow of what they look like, starting to think that there just a dust gaurd, thanks for reply again.
                        • stocious
                          • Jul 2012
                          • 838
                          pic of subrame for comparison later
                          worn wheel bearing and this is the root of my abs problem i bet lol, was loose like that when i pulled the drive
                          and does anyone have the part number for these two, im not trying to explain to the stores guy. and what are they, dust sield of some sort ?
                          found some right nasties in and around the front such as self colapsing shocks lol and very very bad top mounts. the joys
                          • stocious
                            • Jul 2012
                            • 838
                            abs sensor also died on the way out of hub, £££, sh*t !!
                            • irishs2
                              • Apr 2009
                              • 2455
                              I dont have that ring on my ABY but this looks like it
                              893407231 ... Protective Ring
                              Pic included
                              Eric
