Alex,
Thanks for sharing all of the details big and small of how you got on with this UrS4. Helps to make me feel better about my cars, when I see others 'suffering' - Sorry.
Quick couple of 'questions'.
1. How much is a new mirror switch? (The 'bulbs' inside can be fixed but I can't / don't feel confident doing it).
2. Heater Motor, consider replacing the Matrix with a dealer supplied matrix, expensive, but you'll never want to do this job again on the car.
3. After run pump - I presume you mean the two pin sensor ?
4. Suspension - my own suggestion based on daily'ing my own UrS6 saloon would be Bilstein sports shocks to match lowered H&R 29800 springs - The lower the car and take the 4x4 look off the wheel arches but still allow the underneath not to scrape 'pillow' speed ramps.
If the budget allows source UrS6 plus rims - 8x17 with Michelin Pilot Sport tyres in 255x40x17.
Won't be quite as 'hard' as 255x35x18 on Mk 1 S8 Avus rims - 8x18.
5. What clutch did you use to replace your 'broken up' clutch ? Is the pedal any lighter ?
I presume your pedal is not squeaking ? The early signs of the pedal box cracking due to an old and heavy to operate clutch. BTDT.
Why or how did the smoke / water issue clear itself ?
Thanks.
Thanks.
Part of me wants to keep a KKK turbo though, I just love the noise they make spooling and the old school power delivery - even on the 7000. Wonder what the max HP is on the RS2 turbo with stock AAN internals, imagine that turbo could bend rods easily with too much boost though
