Ok so thought it was about time I created a project thread and added a few pics. I picked this car up about a month ago now, and have slowly started to restore her.
I have wanted a 100 S4 for a very long time and have now finally got one
This is how I picked her up, gave a quick wash.
Rear light cluster on the boot was letting in water badly, I have cleaned up the inside of the boot and removed the old light cluster ready for spink's replacement
After spending a few solid days cleaning, suddenly the clutch started acting up. She is in my garage for the time being until I can afford to get that done. In the mean time:
Headlights and indicators have come off for a clean up / replacement. The drivers side projector needs a new reflector due to water ingress. Grille also removed for a good clean.
Spent the day giving her a good wash and polish, removed minor scratches and finally a decent coat of wax, it has made a huge difference.
Sorted out rear badges to my taste, boot trim is on the way
I have also fitted a new master and slave cylinder. Most important things at the moment are a good service, fixing a coolant leak (could be serious as it's leaking quite a bit and can't visually see it) and the clutch!
Will keep this thread updated with any progress I make, have a huge list of things to do and would love to bring her down to ADI next year looking good! Big thanks to trist28 who sold me the car, he is a great guy and has an amazing collection of Audi's and others!
If you remove the bolts for the light cluster inside the boot, it is then possible to get something between the boot and light cluster to separate the old seal, you have to be careful as I nearly broke the old cluster tying to get it off. I see no reason why you couldn't clean both surfaces up and re-apply a new seal, it is nasty stuff though.
So the gearbox needs to come out
I might start a thread about that later though.
Hopefully iv'e done it all correctly. Most concerned about the rear main seal and clutch work- the assembly lube is a year old now so hoping it will hold up, did take lots of care and attention when installing. Don't think I could handle pulling it all apart again!
Plan is to go Holset HY35 / HX35 when everything is running well, so not to fussed about it at the moment!
