Audi S2 Coupé -91 - Some fix & Tuning!
  • Niklas_S2
    • Feb 2013
    • 74
    Thanks!
    Originally posted by anthonys2
    Enjoyed looking through this thread and what a stunning S2 absolutely amazing great job with all the engine bits and what a stunning looking car well done mate!
    Thanks man!
    Spent a couple of hours this weekend in the garage...
    The fuelpumps placed in the hidden compartment at the back of the car.
    The only things visible...
    And a pic on the enginebay.. Seems very empty on the exhaust-side Only for the car inspection
    • Niklas_S2
      • Feb 2013
      • 74
      Exhaust!
      • Niklas_S2
        • Feb 2013
        • 74
        Exhaust
        Have not decided what turbocharger I am going to run with.
        I run with T3, and want to pull 6-700hp at the engine...
        Any suggestions?
        • mushasho!
          • Apr 2007
          • 163
          Any suggestions?
          Depends on what fuel you're planning on...
          Sent from my HTC One using Tapatalk
          _Rubí_
          • Niklas_S2
            • Feb 2013
            • 74
            E85 "Ethanol"
            • mushasho!
              • Apr 2007
              • 163
              E85 "Ethanol"
              Any of these would get you there with ease:
              Forced Performance HTA3582r, HTA3586r, PTE6262, GTX3582r, Super40, Comp6262, ect.
              You can get better spool with a smaller 58mm wheel but would most likely need to run above 2.4bar, need cams and porting.
              _Rubí_
                First time I've seen this project - wow
                • rynaqui
                  • Mar 2012
                  • 2752
                  • Country: Malta
                  #38
                  Same, very very clean looks to be running big numbers soon!
                  1996 S2 ABY Silver
                  • Niklas_S2
                    • Feb 2013
                    • 74
                    Thanks alot! I´ve been looking at PTE6262 and GTX3582r and they seems to be solving my HP...
                    Yeah, i thought that too, but i´ll be running most likely at 2,4-2,5bar.
                    Here is my setup:
                    3B-engine / 2,2L
                    Engine setup:
                    Block
                    #H-Beam Rods
                    #Balanced (pistons, rods, crankshaft, flywheel, clutch and crankshaft pulley)
                    #Cylinder block is Milled and Honed
                    #ARP-bolts for flywheel, crankshaft, rods and cylinderhead
                    #Homemade surge protection in the oil pan
                    #Steel gear on the crankshaft
                    #ACL Bearings
                    #Bushings in Delrin to the engine and gearbox
                    #New waterpump
                    Cylinderhead
                    #Ported
                    #Milled Valves and seats
                    #New valve guides on exhaust side
                    #Milled to the deck surface
                    #New valve seals
                    #Stiffer valve springs
                    #7A Cams
                    #Tommi´s Billet adjustable cam gear
                    #New timing chain
                    Exhaust
                    #Turbo (Not decided yet) (T3)
                    #Cp-service exhaust manifold
                    #Stainless 3" with 3,5" downpipe
                    #Turbosmart 45mm WG
                    #Turbosmart 50mm Blow off valve
                    Intake
                    #Home made intake of aluminum with fullradie hoppers
                    #Original throttle
                    Fuel
                    #Braided fuel lines AN8
                    #E85
                    #Bosch 1700cc fuel injectors
                    #Aeromotive BTR
                    #Fuelpumps - 1 Bosch 040 in tank and 2 Bosch 044 after catchtank
                    Gearbox/Clutch
                    #Sachs 707 push plate
                    #Sachs 4-pad torsion sinter-pad
                    Ignition
                    #Megasquirt v3x
                    #VAG 60-2 trigger at crankshaft from Audi A2
                    #VAG 115R-coils
                    #Hallsensor from ABY/AAN
                    • Niklas_S2
                      • Feb 2013
                      • 74
                      Hehe, thanks!
                      • Niklas_S2
                        • Feb 2013
                        • 74
                        Been in the garage this weekend
                        Oilcooler in place
                        Cut my intake to fix some fitment
                        The fuelrailen will be "build in", and will give the fuelinjectors a better angle
                        Fixing some vent for the 7A-valve cover. Will place a 90degree connection in the back of the cover so it will be hidden. Then a hose to my oil catchtank.
                        Mounted the front bumper last night.
                        //Niklas
                        • Niklas_S2
                          • Feb 2013
                          • 74
                          Hope this will due for ventilation of the valve cover.
                          Drilled a hole and welded a bit by the hole.
                          Also welded a tiny bit of cover on the inside.
                          Will put a 90 degree tube connector on the side against the firewall pointing at the gearbox.
                          • quattro-nick
                            • Sep 2012
                            • 1746
                            • Country: Belgium
                            #43
                            nice wheels on your car,i like them a lot!
                            You've done a great job on your car so far, keep us posted!
                            TWINCHARGED power,zero lag
                            AEM W/M injection
                            • Niklas_S2
                              • Feb 2013
                              • 74
                              They are nice, yeah I sold them a few years ago, but I am going to buy 18" instead of 19" of the same type of rims
                              Thanks alot!
                              • Niklas_S2
                                • Feb 2013
                                • 74
                                Today i finished the wiring of the ECU and tested the in/outputs
                                Hope to startup next weekend or something like that
