Audi S2 - 395HP project done
  • diogocartier
    • Jan 2012
    • 151
    • Country: Brazil
    Guys I have some news...
    I have this car for 14month and it was stock until the last week.
    During the last 3 months I used it for only 200km.
    During this months I have replaced both knock sensors, 2 coils and aircon compressor.
    Beside these issues, it was only good things.
    On brakes I'm using the brake lines from Hell (Aeroquip), Red EBC Pads.
    During the last week I did the following mods on the car.
    3" Exhaust system without CAT
    Silicon hose from Roose
    K24-7200 de RS2
    Unichip Q+
    Fuel Nozzles - 660cc
    New N75
    DV from Forge
    Vacuum lines
    The result is 395HP & 51Nm of torque
    Rgds,
    Diogo.
  • Drummer87
    • Oct 2009
    • 1644
    • Home: United Kingdom Current: Scotland
    Good work
    Lets see under the covers also where did you buy your cover from??
      What wheel hp to crank hp correction factor did you choose?
      Something seems very wrong with those graphs. Torque should drop as HP increases.
      A tuned AAN (similar to ABY and ADU) dyno result:
      Another one:
      Yours:
      • bluequattro
        • 2960
        What was base engine spec to start with?
        Im/em and intercooler stock?
        • Rocco
          • Aug 2007
          • 6393
          • Country: Spain
          I've never seem before any near hp with stock Rs2 turbo!
          Please take off the cover and make some pictures
          • VagOrBust
            • Feb 2010
            • 107
            • Home: Netherlands
            Since Brazil is the worlds second largest Ethanol producer, I'm guessing he's not running on petrol anymore.
            5 cilinder addict:
            1995 UrS6, 2.2 turbo, daily driver, EFI coilkit, custom exhaust.
            1993 S2, 2.2 turbo, ABY, long term project.
            2006 Ford Fiesta 1.4 TDCI. Because reasons.
            • diogocartier
              • Jan 2012
              • 151
              • Country: Brazil
              Guys,
              I´m using petrol 99 octanes.
              The intercooler, intake are stock, basically the hole engine is stock.
              I´ll need to check which correction we used.
              But the car is running pretty well, I´ll do a comparison with other cars..
              I´ll let you know!
              • Maniche
                • Jun 2013
                • 13
                • Country: Brazil
                Just waiting for the healthy comparisons
                Good to see these numbers... Congrats!
                Audi S2 Sedan 1994
                ABY + ADU upgrades
                • Rusty
                  • 18953
                  That graph doesn't show torque, it's just power and run-down losses with the two added together above
                  • Maniche
                    • Jun 2013
                    • 13
                    • Country: Brazil
                    BAU for dastek dynos...
                    Audi S2 Sedan 1994
                    ABY + ADU upgrades
                    • Matt5
                      • Jun 2013
                      • 9
                      • Country: Brazil
                      Maniche e Diogocartier bibas!
                      • Guslotti
                        • Mar 2011
                        • 182
                        • Home: Italy Current: Brazil
                        Did you change the ECU sensor pressure (250kpa to 300kpa)?
                        • Maniche
                          • Jun 2013
                          • 13
                          • Country: Brazil
                          Fala Biba!!!
                          Translate: Hello Fag!
                          Audi S2 Sedan 1994
                          ABY + ADU upgrades
                          • diogocartier
                            • Jan 2012
                            • 151
                            • Country: Brazil
                            Maniche e Matt5 = Bibas... hehehe
                            I'm not using the Map sensor anymore....
