8.3) The cambelt guards and cover have been modified to fit the taller block.
8.4) So did turbo's oil and water feed and return lines, and
8.5) power steering pump belt (35mm longer).
8.6) Bolting the gearbox to the engine has been a tough challenge as well (take into account I did all the work by myself, alone).
Took half a day by itself:
didn't have the tool for centering the clutch disk, neither had the chance for having one borrowed, so, after some unsuccesfull tryes I've thinked out a solution:
Instead of torquening pressure plate's allen bolts to the flywheel, I fitted only theree exhagonal bolts at a low tightening level, so that to leave the clutch disk lose enaugh to have it self centering the gearbox axle.
Once inserted the gearbox, I tightened the exhagonal bolts through the hole in the following picture, took the gearbox off again, fitted and tightened the remaining allen bolts, and finally replaced the three exhagonal bolts with the OEM allens.
Pretty complex and long procedure, but couldn't see any other way.
