SQ LWB road car
  • Tk1
    • Jun 2014
    • 36
    Great thread, all handy as I have similar plans ahead
    Are they cool-wheels panels ?
    • Simons
      • Jul 2007
      • 530
      • Country: Spain
      #62
      Thanks mate, it's a small project
      This body kit is made from Tomasz cecot, but I have another kit from cool-wheels to make another SQ LWB, when I finish mine, and have some diferences
      http://www.rallycarsforsale.net/clas...tails&id=69605
      Tomasz's fiberglass it's more stiff and I think that it's more fragile and has some bubbles...
      Cool-wheels fiberglass it's more flexible and a little bit thinner
      Tomasz's kit it's based on a quattro A2, all except SQ bonnet, grill, front bumper and metal sills. You can buy a sump guard (I have it) also you can fit the rear quarter panels like me or without removing the oe panel, cool-wheels only with oe panel. Shipping cost are cheap and good delivered
      Cool-wheels' kit is fully based on a SQ, rear quarter panels, rear bumper and I think that front fenders are differents of mines...the grill has much better quality than Tomasz. You can buy front rings for the grill and front end cross bar. Shipping cost aren't cheap like Tomasz and not very good delivered...maybe because they send me 3 times with differents companies and the package was damaged
      I like quattro A2 rear end, because if you want, you can buy a quattro A2 front end and you can have an audi quattro A1 or A2 replica
      Hope this help you
      • Tk1
        • Jun 2014
        • 36
        Brilliant info as I am on the verge of buying a lwb sq kit from them
        I have already ordered a coupe sport style bonnet
        • Simons
          • Jul 2007
          • 530
          • Country: Spain
          #64
          Some news, I removed the old engine, batery support and A/C system. Also I cleaned the engine bay, primer and paint in alpine white and fit the new engine
          Old engine out
          batery support out
          A/C evaporator out
          All A/C stuff out, I save 21,8kg and the batery from his old place, another -10/15kg in the right side
          Engine bay clean & sand
          2k primer and paint
          Flywheel with the firing pin, refaced, lighten -1kg (isn't to much...but I'm going to make a new aluminum crankshaft pulley with only 2 channels to save more weight in the crank and have more room for the ic), also I did another 6 holes to help the cooling (and save another grams) and balance
          the new heart
          • kibby
            • Sep 2009
            • 165
            Lwb sport Quattro
            Great project mate watching this closely as an doing a similar project myself a widearch ur,
            • Tk1
              • Jun 2014
              • 36
              Lovely
              My one is in very early stage but panels have arrived
              Be prepared for questions from me ��
              Keep up the great work
              • Simons
                • Jul 2007
                • 530
                • Country: Spain
                #67
                Thanks guys, Keep ahead with yours projects!! mine it's a little project, I don't want to spent more than 15k with all...working hours are free
                • irishs2
                  • Apr 2009
                  • 2455
                  Good progress there. I hope to build a lwb too some day.
                  Keep the updates coming, I look forward to them
                  Eric
                  95 S2 Avant under rebuild.
                  • Tk1
                    • Jun 2014
                    • 36
                    Any more updates ?
                    Thanks for posting all the pics of fitting your 1/4 panels I need all the help I can
                    My cool wheels panels are going to need a lot of work on the sill area
                    Where did you get the metal sills from ?
                    I am also starting with a non ur n/a coupe quattro
                    • Simons
                      • Jul 2007
                      • 530
                      • Country: Spain
                      #70
                      C'mon mate! don't wait anymore
                      Originally posted by Tk1
                      Any more updates ?
                      Yep, but I haven't got pics...now I'm making the steering pump support
                      They have fiber sills to attach on the originals. Mine are from Tomasz
                      • Simons
                        • Jul 2007
                        • 530
                        • Country: Spain
                        #71
                        More pics, the hot side is almost finish, EM, turbo, oil & water lines, wastegate and downpipe. I did a custom rear braket for the steering pump and I'm making the IC braket, I need to do the bottom IC support and two square bars across the IC, one on the back (top side) and the other on the front (bottom side) to give more streng and try to avoid the bottom strut bar
                        • Simons
                          • Jul 2007
                          • 530
                          • Country: Spain
                          #72
                          IC support finished. I hope to don't break the IC with the torsion, if breaks i'll put some rubber mounts between the braket and ic...also I need to cut a little the angle bars, top and botton
                          • Simons
                            • Jul 2007
                            • 530
                            • Country: Spain
                            #73
                            More news, I finish all except the front brakes, paint the body and little things. I put the batery in the trunk, 044 bosch fuel pump, coupe sump guard, 280x22 rear brakes with 42mm calipers, made the exhaust with one cat(middle section only to pass mot), change the stereo to the left side and put three gauge in his place, and more bits. I'll put more photos
                            • Simons
                              • Jul 2007
                              • 530
                              • Country: Spain
                              #74
                              • SteveH
                                • 4460
                                She's alive!
                                91 Modded 3B
                                14 A6 Avant Black Edition
