My Audi S2 coupè Version 2 - full restore - Red rocket from Norway
Originally posted by kinaputt View PostIs it possible to disassemble the parts inside the mirrors? I did try with a spare mirror, but all i do is crack plastic and destroy it.
I know it is possible to take the RS2 mirrors apart, but they are different. The painting of the mirrors did not turn out good enough the first time. It has to be re-done.
Does anyone know a transparent foil i can use under the parts that is going to be riveted on to the body? The original i no longer available. AKL44830004
Does anyone know what center bearing and rubber boots i can use on the propshaft?
And more parts!
2018-03-04 16.23.47 (Copy).jpg I need the white part new. But when i ordered it at Audi Tradition, i got a different part, and it does not fit.
What CV boot can i use for the prop shaft? Ford Sierra stuff? What center bearing? I heard a BMW bearing does fit.Attached Files
Lovely lovely job
shame that the copper brake pipes want stay so nice and shiny for long time.i put heat shrink on mine so they just black pipes now instead going green in few years(or months)
Paintwork looking stunning-who did it for you?
Originally posted by Tractor Dave View PostTop job. Brake lines look very good indeed. If you fancy a holiday to Wales, all mine need doing
Originally posted by Greg_S View PostI would also coat the brake lines in waxoyl to protect against corrosion
Originally posted by Error404 View PostI am going stainless next time
Originally posted by kinaputt View PostWhat CV boot can i use for the prop shaft? Ford Sierra stuff?
Originally posted by kinaputt View PostAre they harder to bend? Expensive
More expensive than copper lines, but not that expensive to frighten someone who restores a car with such a great quality level.
What I can't find still is OEM-style brake line fitings M10x1 made out of stainless steel.
Originally posted by tango123 View Postyou can use copper nickel brake pipe, it wont corrode.
Stainless is much harder so you need high quality bending tools and it is less forgiving. You need really to get aero tubing which is true seamless with a thin wall, and it is quite expensive but not crazy. You also don't need to double flare the female ends as it is far harder wearing . As ShurikeN says when you put this much effort in to a restoration it is worth the effort and extra cost.
I plan to convert to -3AN throughout using 3/16 stainless tube, but you can buy M10x1 fittings pretty easily here in the UK.
https://www.automec.co.uk/collection...-pipe-fittings
