...and any suspension and engine bolts, banjo bolts, fuel fitings, stainless screws, exhaust brackets and hose clamps as well.
My Audi S2 coupè Version 2 - full restore - Red rocket from Norway
I have accepted that this car will not be perfect, because its the first car i restore. The next one will be better as i learn on this one. I am pleased with all suggestions for improvement.
This gallery has 1 photos.
More work done!
New grease and boots.
New bearing.
Anyone want a injection? I used this for the suspension uniballs.
The needle bearings take some time to get in place.
Nom nom!
This sound deadening job takes for ever!
2018-05-12 18.40.06 (Copy).jpg Oh no ...
The probshaft is balanced. I have to add some paint where they attached the new steel plate
2018-05-30 19.35.17.jpg Some spacers had to made because the front bumper has a very bad fit.
2018-05-15 18.03.47 (Copy).jpg This is version 1.
2018-05-15 16.59.51 (Copy).jpg2018-05-15 17.00.00 (Copy).jpg The attaching plate in the rear of the bumper, where attachment to the wings/fenders are 2cm to much to the rear!
2018-05-15 18.10.20 (Copy).jpg2018-05-15 18.10.11 (Copy).jpg They are not even the same length ...
Some more bad fitment and fabrication pictures.
2018-05-20 16.59.50 (Copy).jpg This where bent and cut from a aluminium plate and I drilled holes and glued them on with Wurth 2K plastic glue.
2018-05-20 18.40.27 (Copy).jpg2018-05-21 11.15.28 (Copy).jpg2018-05-21 11.15.44 (Copy).jpg2018-05-20 18.41.43 (Copy).jpg2018-05-20 18.41.26 (Copy).jpg2018-05-21 11.24.44 (Copy).jpg
- 1 like
In such comfort conditions cheap roller stud extractor works and the process is faster. Sometimes even with studs in cast iron (exhaust, turbine hotside). And you save many old expensive OEM studs reusable.
I use welding only when there is no chance to use extractor or 2 nuts tighten strongly together.
Such Snap-On extractor seems to be the best, but expensive:
It should save studs thread even better.
- 1 like
Originally posted by rxl View PostMust be one of the cleanest builds on here. What material do you use for sound deadening
I doubt your car will leak after all the care and attention put into it but, that sound proof material sounds ideal to withstand the infamous Coupe foot well leaks!
The paintwork looks amazing good quality - it is going to a VERY nice car once finished but, will you please hurry up i can't wait to see it done!
- 2 likes
Nearly a year since the last update ... My log says only 270 hour of work on the car in that year. I have also become a student!, that is stange, because i am soon 28 years old ... I am doing a bachlor in Technology design and managment. So lets start with some pictures.
The painters said i had to glue the rear bumper again.
2018-06-10 12.13.45 (Copy).jpg2018-06-21 18.57.52 (Copy).jpg2018-06-21 20.02.08 (Copy).jpg2018-06-21 20.34.52 (Copy).jpg I can not afford to make a new exhaust now. But i did clean it up to make it less ugly.
2018-06-12 19.45.07 (Copy).jpg I did clean the valves before they went to the machine shop.Attached Files
- 1 like
