Pop, yes they will separate your head from the upper body haha no , that´s not the same... it´s not even legal to wash your car outside with any solvent or degreaser But hey that doesn't stop us
1995 Audi S6 - AAN (~350hp)
2008 BMW 530xd (235hp)
Good luck with the project
Be careful with silicone sealant.Seen lot of red one used at thermostat cap.Take oilpan out and see if someone used high amounts of sealant and inspect oil suction tube of the oilpump and inside the pump for sealant.Also suction tube to oilpump oring be sure it is new or pump will get air instead of oil.
Try not to use any sealant,just new gaskets,new orings.
Well,the plan is to use only gaskets w/o any sealant(which i found on old water pump)
I searched for quality gaskets so sealant is not needed(i hate when i see it on any car)
well my friend it it not small project at all ... you take a big job to do !
I wish you a luck , and make it like real urS4 have to look like !
why did you take out all electric instalation? to paint the car?
In that case you will need spacers as they are ET50? I used A6 4.2 rims, pretty much the same style but with ET35. I think they really don't need paint but that's up to you.
Why not try it as they are? You might like it against the daytona grey.
