Audi 200 4.2 V8 to be
  • Kieron20V
    • Mar 2008
    • 1505
    Originally posted by S4KM3
    There is only one way to find out..
    The i5 uses bearing on the flywheel.. i have one at home with bearing.. im just on the way to the garage so i will see..
    Sent from my GT-I9100 using Tapatalk
    The I5 with an 01A or 01E uses the bearing in the flywheel, correct. But in the 200 with the 016 the bearing is pressed into the end of the crank.
    You could remove the bearing completely from the flywheel completely so the shaft passes through it and then find the correct bearing size to press into the crank, or have an adaptor machined to take the correct 01E bearing. I believe 034 used to do one.
    Hope this helps.
    Kieron.
    1994 URS4 Avant RS2+
    • S4KM3
      • Apr 2014
      • 20
      • Country: Croatia
      Cheers mate
      • S4KM3
        • Apr 2014
        • 20
        • Country: Croatia
        The project has stopped for a bit but guys from 034 jumped in and i am just waiting for the insert to use when fiting 016 gearbox with S8 flywheel..
        I only must use AAN clutch... i must fabricate the mounts and it is ready for startup..
        • RS2
          • May 2005
          • 400
          I wonder if you could do me a favour please?
          Could you take a photo of the back of the S8 flywheel that you have please?
          I'm interested to see how it centres onto the crank.
          MG
          • S4KM3
            • Apr 2014
            • 20
            • Country: Croatia
            #20
            Hi m8.. if you need the photo i will take one on monday.. i just came from the garage and forgot to take a picture...
            • geneandbolly
              • Sep 2013
              • 1356
              that should be a very impressive car when it's done - well done you . .
              1997 Audi S6 - The Purple Helmet!
              • S4KM3
                • Apr 2014
                • 20
                • Country: Croatia
                #22
                Cheers..
                I just finished with mounts for V8 front end (including water cooler and air condition)..
                Just welding of engine mounts and she is al done..
                • S4KM3
                  • Apr 2014
                  • 20
                  • Country: Croatia
                  #23
                  The mounts are all done... they are made from 5mm thick mild steel..
                  V8 now sits in the bay like it's in his natural habitat..
                  Next up:
                  Paint job (engine bay)
                  Putting the timing belt on
                  Fitting the gearbox, clutch and the engine in the engine bay
                  Connecting the loom and starting her up [emoji2]
