I5 into audi 80 b4
  • peter
    • Dec 2004
    • 96
    I5 into audi 80 b4
    I am sure this will have been covered somewhere but cant find it!
    There is an abundance of 2.0l 4 cylinder auto 80s and 90s here in NZ.
    What is involved in fitting a 2.3 i5 into the B4.
    I was thinking transmission or engine mount issues etc?
    The engines sometimes come up for sale with or without transmissions (usually auto).
    Sometimes a wrecked 2.3 car comes up but getting rare.
    Any info appreciated.
    The B4 body shells were apparently were built with accommodation for FWD or 4WD... so you CAN easily convert a 2.0L FWD B4 saloon into quattro as long as you have B4 subframe, wishbones and other running gear from a B4 quattro donor... you don't need to cutaway bodywork for a transmission tunnel etc.
    There must be someone on here who has already done such conversion. I seem to recall something different about engine mounts between 4cyl and 5 cal but you would need to search or hope for others to respond here with better memory than me !
    I have helped a few guys with 20VT transplants into other B3/B4 body shells - its straight forward if you aren't afraid of some electrical spaghetti into the fusebox etc
    • A80Avant
      • 10873
      • Country: Greece
      Is this verified and true? As it makes my plan of finding a saloon a he'll of a lot easier
      • mdz
        • Jun 2012
        • 775
        • Country: Latvia
        B4 bodyshell is universal - FWD, quattro, 1.6, 2.2T, LHD, RHD and so on. 91. - 93. FWDs even has rear threads for rear subframe. 4cyl and 5cyl engine mounts are the same except front one, but thats bolt-on part. V6 engine mounts are different.
        • afterburner
          • Mar 2012
          • 246
          • Country: Bulgaria
          It's true. All of the holes for subframe/suspension are there. I recall two of the holes not having captive nuts in them, but that's fixable. The only thing missing is the prop support in the back of the tunnel, if I remember correctly.
          • A80Avant
            • 10873
            • Country: Greece
            Perfect!
            • GazzaG60
              • 4133
              not so on b3 though.
              if its a b3 4 pot you need 5 pot mounts. 4pot mounts engine and gearbox to subframe
              • Audicted
                • May 2004
                • 366
                • Home: Jamaica Current: United States
                Most everything covered in this thread by NiTec: http://www.s2forum.com/forum/showthread.php?t=49903
                • GazzaG60
                  • 4133
                  from what ive found so far there's doing it and doing it right.
                  many little differences between s2 and other 80's. not as many on b4 as b3 but I want old school(er)
                  engine mounts, strut brace, wiring looms and thickness, battery n wiring, fan wiring, steering rack and boot sizes, front arms, shocks,brake cylinders.... the list goes on.
                    Wouldn't a smarter swap be a 1.8T or 2.0TFSI into an ex-4 cyl B4 80?
                    • A80Avant
                      • 10873
                      • Country: Greece
                      Not if you already have an i5
                        Have you forgotten this is a 20VT forum - teehee !
                        Seriously though - The 1.8T and 2.0TFSI engines would need B5 or B6 instruments and OE immobiliser hacks and such for them to work properly. Not saying impossible, certainly a PITA and who wants to do an engine swap for a 4-cyl soundtrack anyway ?
                        If the 5-cyl 20VT attaches directly onto the 4-cyl mounting points on the B4 then it makes for a simple life as all the B4 quattro running gear transfers over along with ABY/ADU loom and clocks from any 5-cyl B3 or B4.
                        • bluequattro
                          • 2960
                          What about a v8?
                          I'd like one in my quattro avant.
                            V8 transplants into B3 or B4 have been done before. Can't remember where I saw it - one of the US based forums I think.
                            • bluequattro
                              • 2960
                              There's been one on here but not much detail on the conversion.
                              Motor geek has quite a few a4 v8 conversions , but I prefer the b4 shape (and I already have a v6 avant quattro).
