My first Audi. RS2 from Norway
    replied
    Originally posted by Vorsprung durch Technik
    Sorry bud. The twists looked sooooo much better.
    Agree. One of the best looking wheels on an Audi UrS (S2, RS2, UrS4/S6) and if you have 5 x 130 hubs and can run OE Porsche Twists and not aftermarket 5 x 112 copies, so much the better.
    replied
    If your going teledials then at least use the proper ones.
  • andersg
    replied
    It was the cam sensor, yes. Pretty weird problem, as far as I know the engine wont start with a bad cam sensor. Even so, I drove allmost all summer in limp mode and it was super reliable. Changed the cam sensor when doing the timing belt, and the boost was back.
    Trans mounts from 034, same with the downpipe.
    Theres been some progress since my last login as well, finally got myself some OEM Cup1's. Unfortunately powdercoated black, on the bright side they came with good Federal RSR's. K26 custom billett turbo is in, all new hoses and radiators, engine mounts, H&R Monotube etc.
    First testmount, have raised it slightly since then.
    Now with refurbished OZ Strosek 17x9" with Toyo R888.
    And latest: new discs in the front.
  • Smb
    replied
    Nice to see.
    Was it cam sensor-failure that made it go into limp mode (low-boost)??
    I also did the timing belt job, on one of the two i own this spring, with new tension roller and new toothweel on the crank, waterpump, thermostat.
    where did you buy the trans-mounts? I also want to change those on the two I own. One of them is chipped and it feels like the gearbox moves a bit when accellerating and specialy when i step off the pedal after hard acceleration. I'm thinking to go for the street density mounts...
    And also where did you buy the downpipe? Or did you make it yourself? I want to buy the 034 3" stainless downpipe, but I don't know if it fits properly... I already have the rest in 3" stainless made by ferrita to be mounted. But I'm missing downpipe and cat... Bought it used on finn.no
  • andersg
    replied
    Hi Smb, plenty of news actually!
    Complete timing belt job with waterpump and some gaskets + new cam sensor (finally got my boost back)
    Lots of bushes incl. motor- and trans mounts from 034
    3" downpipe, soon to be complete exhaust
    H&R Monotube coilovers
    Both radiators + all hoses and thermostat is new
    And the best part, new KKK 26 billett special.
    Pics to come!
  • Smb
    replied
    Hi.
    Nice to see more people take care of this oldtimers Any news since last post?
  • andersg
    replied
    The RS2 is slightly on the backburner due to new house and a lovely 2008 Volvo S60 diesel. Got hold of a funky set of Strosek's the other day, 17x9" ET50, fits perfect.
    With some locals on a sunday ride.
  • andersg
    replied
    Well, the RS2 is finally on plates and I've enjoyed it the last two days. I haven't bothered getting a new N75, i'm only getting 0.4bar of boost right now. Need to get my priorities straight and fix it!
    Had a small fire and melted a few inches of wire on both sides of the main airbag loom contact, just below the relays in the cabin.
    Other than that it's missing allmost all the exterior trim (needs paint) and the alignment is all over the place. The timing belt is allso on overtime, so it's back into the workshop after this weekend. Just need to get some miles to make it all feel worth it!
  • andersg
    replied
    Few pics!
    Cruise control stalk in the making:
    Don't know what this is called, but I propably need a new one. I can spin this endlessly. Isn't it supposed to only go 3 rounds and has to be centred before mounting?
    Need to rebuild the servo pump as well, the wheel is not running straight.
    Parts nr for Big Reds:
    See through label!
    And my friends tricked out V70. 2.0L five cylinder turbo, manual and well equipped. Makes a nasty five cyl sound and pulls pretty good.
  • andersg
    replied
    Finally got my faul code reader! Had to test it right away, there was quite a few stored codes after me wrenching like a monkey. Got "no codes" all the way after deleting, except for the SRS/Airbag system, wich is full og fault codes
    SRS codes:
    01025: malfunction indicator lamp faulty
    0588: Airbag ignition circuit - driver side - N95
    0589: Airbag ignition circuit 1 - passenger side - N131
    0590: Airbag ignition circuit 1 - passenger side - N132
    There was one more as well, forgot to take picture of it The 0589 and 0590 is mainly because someone changed to the wrong passenger airbag with only one ignitor, as mentioned before. I'm on the hunt for a bag with two ignitors, but so far it has been a difficult search.
    Progress has been made in the interior, the cruise control stalk is back in and retrofitted to the stalk collumn that was in the car. The wiring and sensors at the pedals was allready in the car, but I'm missing the control box in the engine bay etc.
    Allso got new brakepads, only to discover the Audi parts nr til Porsche parts nr-guide was faulty Ended up with pads for Big Reds. Oh well, they where an easy sell and new EBC Yellow Stuff for Small Reds is on it's way
  • andersg
    replied
    Thanks It's getting there. The 215's where on the wheels when I bought them, I'll either trade for 17"s later on or switch to 225/40 on the Twists.
  • polishing_frenchman
    replied
    Lovely RS2, always loved the twists on B4's, but why the 215's????
  • andersg
    replied
    Lol! No, I looked like a bank robber. The lady in the house did not aprove.
    I am trying to convert the car back to cruise control ATM.
    This thread helped me alot:
    I managed to get the stalk together again, after having it exploding in my face with springs and small plastic bits everywhere. Nightmare! Got it together after some help sponsored by google, but now my driving lights and indicators won't work I'll check the fuses, if that doesnt work I will try to rebuild the stalk again.
    The tires are 215/35/18 on 18x8.5" Twist all around. The are nice temperarely wheels
    replied
    Originally posted by andersg
    been busy spending money on my newly broken tooth, expensive as hell.
    Any photos ?
    Sorry, I'm a bit giddy on a Friday evening.
    Car looks great, nice wheels, what tyre size ?
  • andersg
    replied
    The front bumper isn't properly fastened, thinking of cleaning the IC and the engine bay in the near future so haven't bothered mounting it on the sides. I'm missing the bumper mesh on the driver (correct) side as well... Anyone know where I can get a new one?
