1994 Audi 80 quattro Competition - STW project
  • Spillies
    • Aug 2010
    • 66
    #31
    Originally posted by Wizard-of-OD
    Since you have a more popular engine , I would suggest investing in a serpentine set up from an ABF/2E engine
    Why?
    Just looking at the fuel lines, there are small black plastic dividers that are oem, in addition to the bits of ones fitted, would be good to get, assuming they are not NLA.
    As well as the existing ones you have, there are ones for the rigid sections of the fuel pipes near the dipstick side of the engine.
    Where could I find those?
    And yes I know that the cooling tank is looking old. But still so much to change, everything will be new in the end of the project I think.
    • Wizard-of-OD
      • 926
      • Home: Syria Current: Canada
      #32
      Originally posted by Spillies
      Why?
      Just looks cleaner and you will be able to move into a more popular alternator should you need a replacement and no more v-belts squeeling.
      Still looking out which engine to fit in. A 5 cylinder is obvious, but what about a 1.8t?
      I would keep it 16V if you are staying 4 cylinder since it is allready in there. You can still get alot of decent parts used for the 6A/9A/PL/KR/ABF if you are on a budget.
      Issam N. Abed
      iABED Industries
      iABED Email | Facebook
      The build thread
      • Spillies
        • Aug 2010
        • 66
        #33
        Update, the car is back on the continent after driving on the wrong side of the road for a half year...
        But it was magnificent!
        The investments paid off, the Compi really drives perfect. The engine doesn't use any oil and the sound it makes is breathtaking.
        SOUND: http://vid216.photobucket.com/albums...pszpqkzw4h.mp4
        It's also a head-turner, surely at every gas station I got nice comments on the car. Some English are really petrol heads.
        Also did a lot of driving around; the Yorkshire Dales, Lancashire, Lake District, ... Lovely roads there, and even better scenery.
        • Spillies
          • Aug 2010
          • 66
          #34
          + bought some more new stuff
          2x plate-glass for the side-mirrors + its electrical engines, because the plate-glass was pealing of on the edges and the engines weren't working properly.
          2x turn signals, the clips broke off of the old ones
          • Jack4688
            • May 2010
            • 1004
            Looks really good! I could spend all day driving around the Lake District
              #36
              Were they adversely affected by the paint overspray ?
              Looking good.
              The small back injection lines clips I got from the dealer a few years ago. May be still available. Can't be that many people looking for them.
              I'd be inclined to keep the existing engine as it is, or skip the 1.8T and go straight for an I5t 20v.
              But maybe wait a while and see does the 2.5L later model 5 cylinder engine become popular cheap, with kits for conversion becoming available in a few years time. I can't remember the engine code I am referring to. They're starting to be done in the US. The IROZ Motorsport site may have more information.
              I think it might be the same basic engine that is in the TTRS. Others will be more accurate / informative.
              • Spillies
                • Aug 2010
                • 66
                #37
                The 2.5l engine that was available in the US spec VW Jetta?
                Also a good conversion idea.
                • Spillies
                  • Aug 2010
                  • 66
                  #38
                  And I'm still looking for a windscreen WITHOUT green solar band, do anyone know where to find those?
                  I already had one fitted in, but it was a bad production so there is dirt between the two layers and I want to find a other one. But the supplier doesn't have it in stock anymore...
                  • Spillies
                    • Aug 2010
                    • 66
                    #39
                    The Compi was leaking some oil and after a quick look it was obvious that it came from the oil pan gasket which was getting hard and had some cracks.
                    To replace a rubber of less then 20 quid, it didn't seem to me as a difficult job. But hell it was...
                    It started with the last 5 bolts of the oil pan which were reachless, so I had to remove the frame of the gear box.
                    After unscrewing all the bolts, the oil pan was still stuck. So I had to remove the frame of the power steering, even after that the oil pan was still stuck at the oil pump which is sitting in the oil pan.
                    The only solution was lifting the engine some 10 centimeters and trying to loosen the oil pan. But first some sleep.
                    After lifting up the engine the next day, I still had to unscrew the subframe because the oil pan was still stuck.
                    But then = great succes
                    Respraying the oil pan (since it was now the time to do it ) and refitting the new oil pan gasket
                    From now of on it isn't leaking a single drop of oil
                    • Spillies
                      • Aug 2010
                      • 66
                      #40
                      The day after did a tour with some friends in the Ardennes Forest (Belgium and Luxembourg)
                      +220.000km and counting
                      • Spillies
                        • Aug 2010
                        • 66
                        #41
                        But now my interior cloth is loosening at the driver side, today I pulled it and vacuumed all the old stuff and temporary refitted it with some glue.
                        Does someone has a solution for this? I was thinking a thick double-sided tape to refit it?
                        • quattrostyle
                          • Oct 2006
                          • 6229
                          So you did not remove the remove the subframe to start with? That would have been the easiest way (if the bolts come out that is).
                          Bit sursprised the Competition did not come with an alu oil pan
                          • Spillies
                            • Aug 2010
                            • 66
                            #43
                            No, because then my wheel alignment would have to be redone and I thought the oil pan was removable just by unscrewing the bolts.
                            Oh boy I was wrong...
