Project fast S2 to faster S2 - Australian Edition
  • #76
    Bad luck! I’ve never heard of the cam wheel bolt breaking. What are you going to do about the broken cap?
    • #77
      Yes ive never heard of cam bolt breaking either. Im putting it down to fatigue and over torquing.
      Luckily its not a main cam cap. So im going to have it welded and machined down.
      Current:
      1993 Audi S2 Kingfisher Blue - GTX3582r w/ E85 = 430kw atw
      Past:
      2002 Audi S4 Nogaro Blue Stage 3+ - 250kw+ atw
      2001 Audi S3 Silver - 169kw+ atw
      • #78
        Good news, as you probably know you can't mix n match the caps, well, without line honing them
        Looks like you will have it up and running again soon
        are they stock intake valves? If so I have some spares, FOC I may have a cam wheel bolt too, but I guess you want a new one?
        PM sent re: vacuum booster kit
        • #79
          Alex its been fun.
          No they are stock sized Supertech valves. I dont have any locally so will need to source them overseas.
          As for the bolt i have found an equivelent size bolt found locally but a higher grade 12.9 in lieu of the stock 10.9 tensile grade.
          OEM Bolt size is M10x1.25x30 and 10.9 tensile
          Hope that helps!
          Current:
          Past:
          • #80
            Hey guys
            Just to finalise this build (for now.. lol)
            Limited boost to only 36psi but can go 40. Would probably reach 700hp on 40psi but whos counting...
            Now i need a dog box because went to roll racing last night and slave cyl doesnt like the abuse.
            One graph shows the different boost levels we were playing with.
            Current:
            Past:
            • #81
              Very nice result!
              Audi S4 2.6 20V STROKER kkk26/27
              • #82
                Originally posted by FCP-ENGINEERING
                Very nice result!
                Thanks for all your help Tomas. Your products are excellent quality!!
                Current:
                Past:
                • #83
                  Nice!
                  • #84
                    Excellent Marco
                    RE the dog box, PAR are in your neck of the woods
                    • #85
                      Regarding the problem og broken bolt
                      wasent there a problem with the tommis 2 gen. Cam wheels and catcams fitment
                      they went to far in so the cam wheel wasent in the right position ?
                      • #86
                        Wow i have never heard that and cant find any info on it.
                        Has someone got any experience with this that can respond?
                        Current:
                        Past:
                        • #87
                          I Will try and find the projectpad thread about it
                          • #88
                            Found this
                            https://www.s2forum.com/forum/member...quat44ro/page4. Scrool a bit Down on page 4
                            • #89
                              Found this
                              There you have it.
                              By using the stock bolt with the tommis cam gear and cat cams its shorter by 0.09 inch which is 2.5mm shorter.
                              Probably explains a lot on my end.
                              Now im using a longer arp bolt anyways since the failure
                              Current:
                              Past:
                              • #90
                                Is this 664hp at Wheel of Engine?
                                408kw @ wheel
