Project fast S2 to faster S2 - Australian Edition
  • momento1
    • Mar 2011
    • 358
    • Country: Australia
    #91
    Originally posted by Prosac
    Is this 664hp at Wheel of Engine?
    No
    At all 4 wheels
    Current:
    1993 Audi S2 Kingfisher Blue - GTX3582r w/ E85 = 430kw atw
    Past:
    2002 Audi S4 Nogaro Blue Stage 3+ - 250kw+ atw
    2001 Audi S3 Silver - 169kw+ atw
    • Prosac
      • 108
      Ok. 664whp? What Fuel? Bioethanol? 39psi (2.4bar) 700++hp at Engine Is Great.
      408kw @ wheel
      • s2dk
        • Jul 2016
        • 507
        • Country: Denmark
        #93
        Dont Think its Cuz the bolt is shorter its the thing that it goes to long into the tommi wheel
        but i dont know
        • jaychen
          • Jun 2013
          • 269
          #94
          Yes he use E85. 664 horsepower measured at the wheels which is more like 800hp at the engine
          • momento1
            • Mar 2011
            • 358
            #95
            Yeah sorry i didnt reply.
            Pretty much what jaychen said
            But im only running 36psi not 39
            Current:
            Past:
            • momento1
              • Mar 2011
              • 358
              #96
              So latest at the moment is the car is back off the road to do maintenance and also to do a big tidy up of the engine bay and underbody
              Removing alot of excess pipes, lines and wires etc.
              While im at it we are aiming to do vacuum brake conversion and single vane pas comversion to delete the bomb. Parts and servo for conversion thanks to Alex
              Also brakes will be getting refinished and also new pads and new rotors are needed. Old 350mm ones are toasted.
              But the main maintenance is the gearbox full rebuild.
              Finally received my PAR gearsets and stronger 26 spline(also know and chevy spline) input shaft.
              New ratios for 1st/2nd is 2.82/1.92
              That should assist with that pesky short first gear and second gear drop off out of peak boost ive been having.
              During rebuild i am also having 3/4 gears will be shot peened for added strength and isotropic polish finish for less friction and ideally cooler running
              Ordered a new spec clutch disc from LM Performance in the US with the 26 spline hub
              Lol... really is never ending.
              Current:
              Past:
              • momento1
                • Mar 2011
                • 358
                #97
                So a really strange thing happened to me last week.
                I sneezed and accidentally bought this 1000hp garrett turbo
                And somehow they managed to drop a brand new eboost2 into the box as well
                In other news my new clutch disc arrived with the larger 26 spline hub from the US
                I dont know how im going to explain these innocent and accidental purchases to the missus.
                Current:
                Past:
                • diesel des
                  • 3896
                  #98
                  Is that a gtx35rs or even larger?
                  Sent from my Moto G (5) using Tapatalk
                  • momento1
                    • Mar 2011
                    • 358
                    #99
                    Spot on
                    3584rs with 0.83 stainless rear
                    Current:
                    Past:
                    • mackenzie50
                      • Mar 2010
                      • 740
                      [QUOTE ] I dont know how im going to explain these innocent and accidental purchases to the missus.[/QUOTE]
                      You can't mate- she knows you too well !
                      • diesel des
                        • 3896
                        #101
                        It will be interesting to see the new power graph!
                        • momento1
                          • Mar 2011
                          • 358
                          #102
                          Haha
                          Yeah she just shakes her head at me.
                          Very low expectations to say the least!
                          But super supportive so i am very lucky
                          Current:
                          Past:
                          • momento1
                            • Mar 2011
                            • 358
                            #103
                            Yes same here
                            It will be a straight swap comparison too.
                            So real world difference between turbos will be good information to share.
                            Im estimating very similar spool up, possibly 200rpm difference at most.
                            The 34rs has improved turbine flow design but is the same size as my current turbo rear gtx3582 gen 2
                            Current:
                            Past:
                            • Acki
                              • Mar 2014
                              • 302
                              Made my day :-D
                                #105
                                This upgrade is gone past bonkers - those power numbers are mental.
