Project fast S2 to faster S2 - Australian Edition
  • My strut brace
    Although mine is nicer than that one in the pic
    Car is looking great mate. I keep thinking its coming into winter now, but of course its your summer! I bet you can wait to let the beast loose
    Keep us updated
    • Originally posted by Error404 View Post
      My strut brace
      Keep us updated
      Yes and your strut brace which still isnt fitted in those last pics. I will put that on last so it doesnt get damaged as its just too pretty. Lol
      Yes summer is coming and it would be nice to be cruising around. Not long to go
      Current:
      1993 Audi S2 Kingfisher Blue - GTX3582r w/ E85 = 430kw atw
      Past:
      2002 Audi S4 Nogaro Blue Stage 3+ - 250kw+ atw
      2001 Audi S3 Silver - 169kw+ atw
      • Hehe yes cherry on the top
        Cant wait to hear the dyno runs and subsequent fly-bys
        • Looking very nice indeed. Keep up the great work
          91 Modded 3B
          14 A6 Avant Black Edition
          • Hi , what are the specs on the rims and tires ? 17?
            • Originally posted by S2_avant 19930325 View Post
              18 x 8 +35
              Rears have 20mm spacers and fronts have 15mm just to clear the brakes
              Tyres are Federal 595RS-RR 225/45
              Current:
              Past:
              • Originally posted by momento1 View Post
                All the parts?
                Which in particular?
                Anything i missed?
                Only the ones I left photos of in my initial message)
                Audi S2 Avant Ruby Red
                • Engine bay complete
                  Needs a clean
                  Current:
                  Past:
                  • Looks awesome mate
                    Have you tried out your brakes yet
                      Looks awesome mate
                      no i havent yet. Still needs to be retuned due tot he additional of wmi and larger turbo housing.
                      I cant wait.
                      Does anyone have any predictions on final power output??
                      im guessing 750whp (approx. 900 hp at the fly)
                      Current:
                      Past:
                      • Engine bay looks very tidy.
                        Any plans for some radiator ducting?
                        Find me on Instagram @pry4sno
                        2010 Golf Sportwagen TDI /// #farmenwagen
                        2002 Dodge Ram 2500 24v Cummins 4x4
                        • Originally posted by PRY4SNO View Post
                          Not at the moment, i have fitted the factory shroud back on and modified it.
                          Previously i was running it with just the spal fan only and it was ok but i wanted it better.
                          Should help it further.
                          Current:
                          Past:
                          • Well im pretty happy with the result
                            760 whp at only 40psi (i want to go up maybe a couple more soon)
                            However i had to turn it down a touch to 38psi because we have a slight issue at that higher boost level now.
                            I believe the oem alternator isnt keeping up with the amp demand.
                            Does anyone know what amps the standard alternator produces??
                            Im running more electrics now (such as the water/meth kit and electric power steering) and coupled with the higher power demand we are seeing ignition misfiring up top at 40psi and also fuel supply tapering off, which it never did before.
                            Are there any direct fit higher output alternators on the market that others are using? Or anyone else experienced this and has a solution?
                            Current:
                            Past:
                            • Would need to confirm a voltage drop at those levels while testing. Having a healthy battery, I would doubt it would be voltage problems though, as peak demands should be sustained by the battery. A DC power analyzer to log voltages might be useful to rule out voltage drop.
                              ABY S2 stroker (work in progress)
                              B5 1.8T quattro
                              B4 2.3 (decommissioned)
                              • Originally posted by Pat D View Post
                                Yes my thoughts exactly. We will be testing in the new year.
                                For now its detuned slightly so i can enjoy it over the break.
                                Moreso wondering if anyone experienced this over the years once they started adding more electrics
                                Current:
                                Past:
