Abt C5
  • aronmatic2
    • 2129
    • Country: Hungary
    #166
    clean job slobodan
    Real carbon parts for S2 and RS2. Check Carbondesign on facebook
    • zlobo
      • 967
      Thanks Aron
      ABT C5 Lord Of The Rings
      2004 1/4 Mile ET 12.00 191Km/h @1,5Bar
      2009 1/4 Mile ET 11.92 213Km/h @ 1,5Bar 437WHp
      2010 1/4 Mile ET 11.45 110Km/h @ 1,5Bar 437Whp
      kostic.nu
      • zlobo
        • 967
        If only the days was longer....
        today i managed to mount the fuel rail and injectors and i also made a heat cower over the filter
        Got some disks from Johan that i am thinking off using 365x32mm from Rs4.
        kostic.nu
        • zlobo
          • 967
          some days ago i filed up the engine with glycol and water an yesterday i found a Small leak on the water pipe so i had to dismount everything and weld the pipe.
          So this evening i managed to weld it and mount everything back i also mounted the fpr and a fuel line. this weekend i will probably make an new engine loom.
          kostic.nu
          • DJ-ROY
            • Dec 2004
            • 710
            great work again Zlobo good luck with the engine loom
            RS for ‘Rennsport’ - ‘Motorsport’ in German
            • s2_bo
              • Oct 2005
              • 6067
              #171
              Yeah, looking really good. Hope the loom goes well and keep us posted...
              91 S2 coupé - RIP
              98 S8 - Luxury barge
              • zlobo
                • 967
                smal update. Nearly everything is on its place. i have started a bit with the loom.
                I also got some bad news today the guy who builded my em died last night in a mc crach R.I.P Peter G.
                kostic.nu
                • zlobo
                  • 967
                  some pic on the engine loom.
                  not 100% finished with the loom. have to get some stuff to get it reddy.
                  kostic.nu
                  • zlobo
                    • 967
                    The ignition key cylinder broke down on Saturday when i was suppose to start :wtf: i had a lot of trouble replacing it had to drill a hole to get out the lock cylinder. and that i had to do with out removing the dash.
                    here is where i need to drill and i managed to do it with a dremel
                    here is the broken one, when i managed to remove it.
                    drilling on a donor one trying to find lock to push
                    found it and removed the lock
                    i also managed to start the engine for the first time today
                    here is a link to a Small avi clip click here or save as..
                    kostic.nu
                    • zlobo
                      • 967
                      The headlights is mounted also the ic.
                      This is the first time it leave garage in a long long time. Mapping will be made in the spring
                      kostic.nu
                      • 4WheelDrifter
                        • Oct 2004
                        • 5773
                        • Country: Devon
                        #176
                        Wow. It runs. Or did you push it out of the garage Zlobo?
                        SS
                        • zlobo
                          • 967
                          Haahaha, No this time i drove it out. i have to do some modifications in the mapp to make it run good. but it's driverble.
                          I am runing on 98oct now and in the spring it will be mapped with E85.
                          I can put some smal movi clips so you can heear the engine running
                          kostic.nu
                          • 4WheelDrifter
                            • Oct 2004
                            • 5773
                            • Country: Devon
                            #178
                            You know we like video clips here.
                            SS
                            • zlobo
                              • 967
                              Ok then, here you go looki lokki
                              i just puted that clip together sory about the bad sound quality in the beginning.
                              kostic.nu
                              • DJ-ROY
                                • Dec 2004
                                • 710
                                Happy for you
