Bens Audi 80 track car project
  • terrybullwon
    replied
    Hub carriers from DMD
  • zafra
    replied
    It's scary....
  • terrybullwon
    replied
    Tail pipe
  • terrybullwon
    replied
    Rota wheels
    Error 404 harness
    4" down pipe and motor
  • terrybullwon
    replied
    Ajustable top mounts set back to 6 degrees of castor before
  • terrybullwon
    started a topic Bens Audi 80 track car project
    I have another car to finish off for some one else with lots of nice parts and toys on. Building it for Club/Pro Time attack spec.
    Out line of spec
    Engine
    GTX35R
    Custom pistions
    KKD manifold
    Antique wagner inlet ( first edition )
    Tial 50mm gate
    Tial BOV
    Adjustable pulleys
    Machined breathers
    Wiggings style fittings with aluminum pipe work
    Solid lifters
    Triple plate clutch
    Griddle plate
    1.8T coils
    Error 404 Raychem harness
    Custom engine harness
    Tatech pro ecu
    4" down pipe
    Rear mounted rad
    dual 044 pumps
    Walbro 450 lift in tank
    1000cc injectors
    Billet fuel rail
    Turbo smart FPR
    Suspension / Geo
    Audi motorsport dampers 2 way adjustable light weight aluminum casings
    Tubular front wish bones with rose joints
    Rear end powerflex bushed with rose joint linkages
    DMD hub to damper billet brackets
    Front strut towers corrected
    Lower king pin extended to correct wish bones
    DMD motorsport steering bracket with rose joints
    MR2 rear mounted PAS pump
    Brakes
    Front 8 piston RS6 DMD carriers
    Padgid RS14 pads
    Rear 4 piston porsche with extra hand brake calipers
    Exhaust
    4" down pipe
    4" oval along centre section
    4" round over shafts to rear box
    3x simonds silencers
    All V bands
    Saftey
    5 point harness's
    multi point cage with suspension tied in
    life line fire
    fire wall
    roll over valves
    Rear rad with Craig Davies water pump
    Fan Cowl and inlet housings from rear window
    Cleaned rack with DMD bracket
    Home made fuel manifold -8AN
