Audi S4 2.2t Build
  • #31
    Originally posted by Aandreaaz View Post
    What other aftermarket arrangements are you referring to?
    Sorry, what I meant was the other aftermarket ventilation systems that people use to replace the factory oem ventilation / recirculation system on an AAN / ABY.
    I was wondering what this diesel piece is in the sump, how does it work, and why is it 'better' that what's used in an AAN / ABY ?
    Thanks.
    • #32
      [QUOTE=macspring;929310]Do you / anyone know what the spec of the AAN cams and the 7a cams are for comparison purposes with the specs of the Shrick cams ?
      Hi there try this:http://www.audiworld.com/forums/audi...-ymmv-2175871/
      HTH
      Lukas
      Or just directly here:http://www.s2forum.com/forum/showthr...?t=1477&page=2
      • #33
        Thanks.
        It just moves the breather inlet inside the engine to the front part of the sump, so in hard lauches the sump oil doesn't go up in the breather hoses/pipes. The bad part is that the breather inlet is now lower down in the sump. This part is found in the AAT engine, not in AEL. There is not enough space in the AAN/ABY block to make the fitting holes for it. You need to make a DIY pipe and fittings or use a good sump baffle.
        • #34
          But way is it used on the diesel? I don't think it is for blocking oil on hard launches
          1360kg/600Whp Avant 0-200km/h 9sec
          • #35
            And why only in the slower diesel..? That I can not answer.
            • #36
              They has surely some clever explanation for it
              2015 Audi A4 Quattro Sports edition
              1992 Audi S4 2.2t Quattro
              1986 Audi 80 Quattro
              1985 Audi GT Quattro
              1966 VW Bug (Herbie replica)
              https://www.garaget.org/Aandreaaz
              • #37
                It getting close to startup
                Just a few things left to do!
                Have changed the steering rack ... for the third time! If this leak I'll go crazy
                Fitted new power steering pump, alternator and painted all the parts before I mounted them back.
                Installed my new camshafts
                Wrapt the downpipe and exhaust manifold
                Installed EGT sensors and new injectors (Bosch 2200)
                Changed to 4 puck clutch
                My 6 puck had slipped
                Just install the new oil cooler and make new pressure pipe, then it's time
                Starting to get nervous about the start-up
                • #38
                  Wow! Great work!
                  • #39
                    Hi, where did u get Schrick cams? ))
                    Audi S6 C4 2.2T Quattro 1997, full rebuild....
                    Audi A5 Sportback V6 2.7 TDI 2011
                    Volkswagen Phaeton V6 3.0 TDI 2009
                    • #40
                      Hi!
                      A friend ordered them for me, but I do not know from where! Can check with him!
                      But you will find sites that sell them if you google Schrick 260 Audi 5cyl
                      • #41
                        Hi!
                        Installed my new Brembo brake discs and Ebc Yellowstuff pads this weekend...hopefully that will cure some off my brake fade!
                        The same set up for the rear brakes
                        Bought poly bushings to control arms and stabilizer bar from AK motorsport!
                        And solid mounts to the front subframe
                        Excited for a testdrive now
                        • #42
                          Hi!
                          Have put some miles on the car by now and it seems to work just fine with all changes.
                          Engine is running well and the oil temp is much better with the oilcooler behind the grille.
                          Like a completely different engine with new camshafts, so much more low end torque/power!
                          Spools much faster!
                          The brakes grip much more and much firmer suspension.
                          Bought some new rims as well.
                          Needed a re-painting, but they became pretty good
                          • #43
                            Nice
                            Looking good Nice with the oil temp to! I have installed a digital temp sensor in the sump after I installed my second oil cooler, it shows like 90-95 deegres at the most. What's your oil temp now? Like your new rims! Also a little yelouse about your cams
