It does not hit the rail, it's pretty close but doesn't touch. Maybe I will add a couple of shims under the right engine mount to raise it just a little bit.
It's a precision 5558 turbo with a 55mm compressor inducer and it's advertised horsepower rating is 650hp. We will see how this turbo works once everything is ready for tuning.
I have an adjustable Tommi's Billet cam pulley. However it was not a direct fit. I had to grind it from several places so that it doesn't interfere with the cam sensor.
This steel ring holding down the cam sensor wheel was too thick. I used an angle grinder to make it a little thinner. Also the bolts had to be shortened.
The engine and gearbox are in! It took a few tries make it go in nicely but got there in the end. It would have been easier with left side engine mount removed but I thought of that after everything was installed.
But now I have another problem to solve. The shifter linkage doesn't want to bolt on to the gearstick. It is also hitting the transmission tunnel. This might be because I renew the linkage ball bushing and I had to put a couple of washers under the right engine mount to give clearance for turbo.
I will probably have to take out the engine and box, remove the turbo and put the engine and box back in without the washers under the engine mount to see if that is my issue. If that's the case, I will have to think of other measures to give clearance between turbo and chassis rail. I currently have a 10mm spacer between turbo and exhaust manifold, making it a 5mm might help.
If it were me I'd try it without the spacer between the turbo and manifold. That said, if there is no issue against the chassis when you remove the shim from the engine mount just leave it in.
I will have to do some testing to see what works best. A little spacer between turbo and manifold has to be left. Without the spacer the compressor housing is too close exhaust manifold, about 1mm between them.
I thought that I will just throw the gearbox and engine in and everything just would work Of course I should have known that changing one thing will have an effect on others. I guess I will have to do some more trial and error and remove and install the engine couple more times
After some trial and error with the shift linkage I noticed that reverse would not engage. I had to take the gearbox back apart to see what the issue was. Everything was assembled correctly, but I only could get reverse to engage if I spun the input shaft counter clockwise (engine spins clockwise). I could have modified the reverse gear synchro plate to make it engage easily, but I decided to set the reverse gear spring a little differently. It's hard to explain in words, but now I can get reverse to engage and everything seems to be good.
Gearbox is now assembled and bolted back to engine and I'm back at setting the shift linkage. I think I have it all figured out now and with a days work or so, I should be good. Then it's just fitting the propshaft and driveshaft and then finally I can start making the exhaust.
Spent this day trying to make the shifter linkage work with no luck. It seems that I can't make the gearstick end of the linkage move like the gearstick moves I'm starting to run out of ideas.
So my holiday started and I'm free to get some work done. Except that I got a cold. It's not too bad though and I could not resist to pay a quick visit to garage.
This shifter linkage issue is solved by new aftermarket one. It works a treat. If I had the patience I maybe could have made the original work. But I'm glad that this is now sorted.
I also wanted to install the heat shield betweed turbo and exhaust manifold. It reguired a little hammering but it fits now. Compressor housing is close to the manifold as is the turbine housing close to the chassis rail. We'll see if the clearances are enough.
And I started I little mockup on the exhaust. The wastegate connection to downpipe will be a challenge for sure. I also should have welded the first section of pipe to turbo V-Band before mounting the turbo for good. Now the space is a little tight but should be doable.
Propshaft bearing now changed and shaft installed. This is the 4th(!) propshaft bearing I've got on the car now. When this fails, I will get a JXB bearing carrier.
I guess the flex joint will be after the cat? If so then why not before?
I'm just curious because my cars exhaust has no flex joint at the moment but as the season is over I plan on putting one before the cat right after the 90 degree turn under the car. It will probably need an extra hanger though. To prevent sagging.
Yes, the flex will be after cat. I used to have it like that before without issues so I thought why change.
I will support the cat to the gearbox and since it moves together with the engine this should work.
I know there will be some thermal expansion between the downpipe and cat and without a flex it may cause problems. The cat support will have rubber isolators that shoud allow small movement.
This is how I thought it, but we will see if it works
