N90297101 Needed for a URS6 new or one in good nick cheers
Diff Seal
Tags: None
They are readily available for any bearing/seal supplier. I posted a list of the part numbers for the Corteco brand in one of the v8 torsen threads, good luck finding it though as the forum search engine is utterly useless.91CQ20v - Gone to a new home
93UR-S4 - The Magic Carpet
94S2Bus - The Emerald ExpressComment
I searched 'diff seal corteco' and got:
and
Those any good?
If you give a bearing/seals supplier the sizes they can normally supply.Comment
been searching wide nothing comes up for that specific part il have a look at that thread you have cheersComment
Assuming its not available from either a Dealer/TPS then its dimensions are listed as 94X3N. Not sure what the convention is with O rings but if thats ID x width + material than its a 94mm(ID)X3mm(W) Nitrile(material) O ring! Of course it could just as easily be an OD rather than an ID!
Thats sort of reading between the lines!Comment
Found this in my email. The part number they sent for the left side was incorrect, but they can cross reference it with the Audi part number.
(AZE Left Side)
Part No: 01020537B
VW/Audi No: 017525400A
other No: XXXXXXXXXXX Simmerring € 20.54 3-4 WEEKS
72x122x10/13
(AXZ Left Side) (V8)
Part No: 01034693B
VW/Audi No: 017525400C
other No: BASLSFRSX7 Simmerring € 56.22 3-4 WEEK
45x122x12/23
(AZE Right Side / CGR Outputs)
Part No: 12017270B
VW/Audi No: 016409399B
other No: BASLDRWX67 Simmerring € 4.62 3-4 WEEK91CQ20v - Gone to a new home
Just checked another resource and the round seal is listed as being Gummi-E70!
I think Gummi is German for Rubber. Not sure whether the E70 is the shore/durometer value or its profile. The other seals listed are either gummi/epdm/nbr etc so perhaps the N is not indicative of material.
Hopefully that should give you enough info to source the replacement. There may be a better solution in terms of material but that would take somebody with more knowledge than me to comment on although if you explain what you need , perhaps a supplier can recommend something suitable.
It does seem that the E signifies Ethylene-Propylene or Epdm/Epr. The choice of material may be important as Epdm has poor resistance to mineral oil whilst something like Nitrile has good resistance. Again a expert recommendation would be good!Comment
Can you elaborate...i searched for corteco and got 7 threads and diff seal and got 57 results. We can take a look with some explicit examples of uselessnesssigpic
1992 3b S2 CoupeComment
